RACEON
05-24-2007, 02:28 AM
I was putting my aux valve body in my 93 Corvette 4L60, when the bolt (long one in picture, wouldnt even start. I took it out and the threads were gone. Then I measured the distance up to where it bottomed out and this bolt seems longer than the hole. But, it was there when I took it out as it was the one with the tab to hold the aux body hydraulic tube down.
My question is , can I tap it? Or put a slightly larger bolt in? Thnaks in Advance
http://i33.photobucket.com/albums/d80/Steve40th/DSCF0351.jpg
12SCNDZ
05-24-2007, 07:21 AM
The correct way to fix it would be to heli-coil it, but there's a few threads left in the bottom of the hole that MAY hold a slightly longer bolt.
Frank
CPT
RACEON
05-24-2007, 02:10 PM
Frank
CPT
Thanks Frank. I will get a stud and see if that will work, otherwise I may helicoil it.
Pete Kane
05-26-2007, 05:08 PM
How did you make out Steve?
RACEON
05-28-2007, 01:27 AM
Well Pete, I put a new bolt in with a slighlty larger thread, same depth. Went quite well. Then of course you know about the 4 gear accumulator ppiston pin I found later :)
Yes Pete, I am all over the net when in crisis mode. :(
Pete Kane
05-28-2007, 02:31 PM
I don't blame you. Lots of good info out there. This forum has quite a few good transmission guys here.
