MeanZ687
05-18-2007, 01:25 PM
I was just wondering if the instalation of LCAs and rear sway bar is easy to do yourself and is there any adjustments that need to be made with the stock suspension?
Lower Control Arms and Rearsway Bar InstalationMeanZ687 05-18-2007, 01:25 PM I was just wondering if the instalation of LCAs and rear sway bar is easy to do yourself and is there any adjustments that need to be made with the stock suspension? ConElite 05-18-2007, 01:40 PM What Dont know. you installing it in a semi, Mustang? Create a Sig. Im sure its an F-body. Many make and model please. TobyZ28 05-18-2007, 03:17 PM Easy to Do: yes Adjustments: no MeanZ687 05-18-2007, 03:41 PM It's a 99 camaro ss MeanZ687 05-18-2007, 03:43 PM I heard the LCAs can cause the rear to sag or somethin? ConElite 05-18-2007, 04:56 PM I heard the LCAs can cause the rear to sag or somethin? NO way. What kind of control arms are you installing? The sway bar is easy. The control arms are easy too. just make sure you have it lifted and supported by the axle. You need to have the suspension loaded. You dont have to but does make it easier. If you have Adjustable Control arms, Make sure they are the same length or else your going to throw your thrust angle off and your steering wheel is going to not be centered. MeanZ687 05-18-2007, 05:21 PM There sphon LCAs non adjustable, would you suggest adjustable? 2000GTP 05-18-2007, 05:27 PM There sphon LCAs non adjustable, would you suggest adjustable? There is not much use for adjustable LCAs other then correcting the thrust angle or helping to accomodate very large slicks. The non-adjustable set should suit you just fine. ConElite 05-18-2007, 06:16 PM There is not much use for adjustable LCAs other then correcting the thrust angle or helping to accomodate very large slicks. The non-adjustable set should suit you just fine. Second that- I only got the adjustable ones b/c they have the Single side solid QA1 ends. | ||
