Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
junkyard injectors
Old May 15, 2007 | 09:25 PM
pyro719's Avatar
junkyard injectors
I am running a 125 shot now and dont want my stock injectors to lock up. I am installing a walbro 255lph pump this weekend, and was wondering if there are any good injectors I could find a at a junkyard that would be better than the stock lt1 injectors? I just dont want to lock the stockers up and go lean!
Old May 16, 2007 | 08:22 AM
2000GTP's Avatar
Unless you can find a set of SVOs or Racetronix, no, not really. What kind of nitrous system are you running? If you are running a wet kit, the injectors should be a non-issue anyway.
Old May 16, 2007 | 09:05 AM
pyro719's Avatar
yes its a dry shot
Old May 16, 2007 | 06:30 PM
2000GTP's Avatar
Maybe try the classified section on here, you may be able to find a decent, used aftermarket replacement set for a decent amount.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
