"NEW" ENGINE, Upgrades BEFORE/AFTER PICS & VID
Old May 12, 2007 | 05:17 AM
camarosource's Avatar
Engine finally DONE!
I recently got the following done to my engine. I had 3 oil leaks in the car, Rear main seal, Oil gasket, and another leak that no one can figure out where it was coming from. Turns out it would be around $1500-2000 to fix it.. And I thought, what's the point of fixing an OLD 15 year old engine. So I set forth to get the engine remanufactured. I then decided to get a cam, ceramic edelbrock TES headers, ignition system, etc. Total $7000cdn
Here is what was done:
1 - New 5.7L V8 350 engine (Rebuilt with new Pistons, Bearings, Valves, Seals, Springs, Lifters, Timing Set, Polished Crankshaft, All new Gaskets, Including Head Gaskets, Intake, Rear Main seal, Timing Gasket and Front seal).
1 - Intake Manifold
1 - 3 Year, Parts and Warrenty (60,000km Warrenty) on all related parts.
1 - Comp Cam
http://static.summitracing.com/globa...08-300-8_w.jpg
1 - MSD Pro Billet Distributor Cap and Rotor
http://static.summitracing.com/globa...e/msd-8366.jpg
1 - BEST Rated Oil Filter - WIX :
https://web12.secure-secure.co.uk/be...s/IMG_8086.jpg
1 - MSD Wires (8.5mm) [BLUE] Heli-Core Spark Plug Wires Kit
http://static.summitracing.com/globa...e/msd-3135.jpg
8 - ACDelco's RAPIDFIRE platinum spark plugs (100,000KM replacement)
http://www.acdelco.com/i/parts/spark..._rapidfire.jpg
1 - Edelbrock (Ceramic) TES (Tubular Exhaust Systems) Headers and Kit Exhaust System with Y-pipe
http://www.jegs.com/images/photos/300/350/350-68792.jpg
1 - Stage 8 Header Lock Bolts
http://www.jegs.com/images/photos/800/868/868-8913.jpg
1 - New O2 Sensor
1 - Labour of course to fit and weld collector pipes to headers
1 - New AC Delco Waterpump
1 - New Thermostat
1 - New UPPER Heater hose
1 - New LOWER Heater hose
1 - New Intake to Throttlebody Coolant Hose
1 - New Radiator Fan Switch
1 - New Tempature Sensor
2 - New Oil Coole Gaskets
1 - New Serpentine Belt
1 - Speedy Sleeve for Harmonic Balancer
2 - Poly Urethane Motor Mounts (Energy Suspensions)
http://www.jegs.com/images/photos/35531116.jpg
1 - Coolant
1 - Oil Change 5W30
14 - Remove and Install Engine with New Components
1 - Fixed hood latch, spring, re-aligned, and adjusted Hood. [FREE]
1 - Front suspension adjustment [FREE]
1 - First oil change (6 months) [WILL BE HALF PRICE]
X - Fixed some grounding wires
X - Re-routed under light wires for a more pleasure appearance
X - BLUE Tiewrapped for needed instead of regul white or black to match color scheme of engine bay.
1 - Complete Professional Interior, Exterior, and engine bay cleaning [FREE]
!!!! - AWESOME MECHANIC. Despite some problems, all if fine now. [PRICELESS ]
PICTURES:
Engine back from engine remanufacturer
http://i17.photobucket.com/albums/b5...s/100_7739.jpg
Old Camshaft :
http://i17.photobucket.com/albums/b5...s/100_7741.jpg
Old valves, retainers, springs, etc :
http://i17.photobucket.com/albums/b5...s/100_7743.jpg
My old intake :
http://i17.photobucket.com/albums/b5...s/100_7747.jpg
Damaged coolant passengeways : http://i17.photobucket.com/albums/b54/camarosource/April%2017%2007%20-%20Pics%20-%20cars%20new%20engine%20and%20headers/100_7748.jpg[/img][img]https://i17.photobucket.com/albums/b54/camarosource/April%2017%2007%20-%20Pics%20-%20cars%20new%20engine%20and%20headers/100_7749.jpg
Here shows the cracks and WELDING the previous owner did (he was a welder). Surprized to see this when they opened the engine up - http://i17.photobucket.com/albums/b5...s/100_7780.jpg
Left over fasteners, plugs, etc :
http://i17.photobucket.com/albums/b5...s/100_7782.jpg
Brand New Headers :
http://i17.photobucket.com/albums/b5...s/100_7752.jpg
Old parts -
http://i17.photobucket.com/albums/b5...s/100_7753.jpg
Apparently the engine had compression leaks, running quite lean, coolant leakage inside the engine, cracked intake, welded intake with the 6 years the original owner had the car (obviously abused!)
BEFORE:
AFTER:
BEFORE:
AFTER:
BEFORE:
AFTER:
VIDEOS - May need to turn up your volume a bit as it may have recorded a bit lower
BEFORE:
AFTER:
An AFTER Video of plain driving, was DARK Outside by the time I got home :
Old May 12, 2007 | 03:41 PM
2000GTP's Avatar
You did a good job on cleaning up the engine bay.
Old May 12, 2007 | 06:34 PM
Chevy16's Avatar
thats a sweet 3rd gen, awsome job, man!
Old May 13, 2007 | 12:02 AM
I didn't.. The professional Detailers hired to do it for me as a complementary service did
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
