what would cause this
Old May 11, 2007 | 12:35 PM
Garcia95's Avatar
when my car is at idle its mussing, and when its running it also misses any ideas as to why. its a 95 3.4 camaro.
Old May 11, 2007 | 02:24 PM
FunkZ's Avatar
Old plugs, plug wires?
Old May 11, 2007 | 03:02 PM
IXLR894Z28's Avatar
^x2
Old May 12, 2007 | 01:34 PM
Garcia95's Avatar
no thats not it i changed them already
Old May 12, 2007 | 03:45 PM
2000GTP's Avatar
Another simple check would be to make sure you don't have any vacuum leaks. Some other potential culprits could be dirty/clogged injectors or a faulty coil pack.
Old May 13, 2007 | 08:46 AM
Garcia95's Avatar
well it has no leaks cause i checked that the other day. but i well check the coil packs and how do i check the injectors. should i just buy an injector cleaner and putit in the gas tank??
Old May 13, 2007 | 01:43 PM
2000GTP's Avatar
An injector cleaner wouldn't hurt. Also, if you had access to a scanner or someone that has one, it would help if you could narrow it down to possibly a specific cylinder.
Old May 13, 2007 | 05:58 PM
Garcia95's Avatar
ok ill get busy after work tonite
Old May 14, 2007 | 06:55 AM
jtblckmaro's Avatar
Mine did the same thing. Ended up being a coil pack. There's a procedure to check it with an ohm meter in the Hayne's manual.
Good luck
Old May 14, 2007 | 03:47 PM
Garcia95's Avatar
thanks man
i know one way of checking it which is bu grounding it out so ill try that and see that happenes.
