Loose suspension rattling noise
Old May 9, 2007 | 10:33 PM
Red95M6Z28's Avatar
I tried a search and got a million things not answering anything for me.
My 94 Z has a loose sounding rattle definately coming from up front. Happens over any small bumps, manholes, etc. Can someone point me in the right direction for what to replace first? Thanks!
Old May 20, 2007 | 05:21 PM
STAYBG87Z's Avatar
check your strut mounts
Old May 20, 2007 | 07:01 PM
2000GTP's Avatar
I would probably check the front sway bar as well, make sure the bushings and endlinks are in good shape.
Old May 20, 2007 | 07:50 PM
Red95M6Z28's Avatar
Can you tell me what to specifically check about the strut mounts? You mean under the hood? on the shock tower? I check the end links too.
Old May 20, 2007 | 09:38 PM
Greed4Speed's Avatar
Could even be a retention spring for your pads has gotten weak. Go over a bump that you'd normally rattle on with your brake barely engaged and if the noise is gone, then it is brakes.
Henson071
Dec 30, 2015 09:55 PM
force10
Jul 30, 2015 04:56 PM
GT what?
Jul 14, 2015 10:17 PM
mrwz28
Jul 8, 2015 09:11 PM
colts0455
Jul 7, 2015 07:19 PM
