testing coolant sensor (pcm, not dashboard)
nfa
05-07-2007, 11:34 AM
While changing water pumps, I decided to test my coolant temp sensor as per shoebox's instructions. I set the multimeter to ohms and touched hte leads together to verify that I am getting a reading then proceeded to put the leads to each of the sensor prongs. Im not getting any reading. Am I doing this wrong or does this mean the sensor is not working?????
Injuneer
05-07-2007, 06:44 PM
A direct short would read "0" ohms. A complete open circuit would indicate infinite resistance. Anything other than one of those should produce a resistance reading.
nfa
05-07-2007, 07:41 PM
I am geting infinite resistance. so this means my sensor needs replacing?
Dave89IROC
05-07-2007, 08:15 PM
if you are probing the sensor, then yes
nfa
05-07-2007, 08:17 PM
Yes, I was probing the prongs of the sensor and getting infinite resistence. I wonder if this was the culprit for the crappy fuel mileage ive been experiencing...
if you are probimg the sensor, then yes
Dave89IROC
05-07-2007, 08:44 PM
likely,
open = reads cold
cold = more fuel injected
