z28luva
05-06-2007, 11:20 PM
my rocker arms were loose so i tightened them. my question is can you tighten them too much? and would it cause the engine not to start?
rocker arm questionz28luva 05-06-2007, 11:20 PM my rocker arms were loose so i tightened them. my question is can you tighten them too much? and would it cause the engine not to start? shoebox 05-06-2007, 11:52 PM If you just "tightened" them without going through the valve adjustment process (http://shbox.com/1/4th_gen_tech2.html#adjust_valves), then you will have to start over and do it right. Yes, too tight can cause loss of vacuum and no start. z28luva 05-06-2007, 11:58 PM ha thanks, i def did it the wrong way. oh well live and learn. i'll fix it tommorow. any tips that werent covered on that website? | ||
