SAR2K
05-06-2007, 11:53 AM
SOLD
I don't play with this toy anymore, hate to see it not being used.
If yore looking for a project car that’s not a basket case this is for you.
You all know what an LT1 Trans Am is, so I’ll skip the common stuff and go over condition & parts. Car has approximately 89,000 miles on it. Body is in excellent shape, but will need paint work since it’s showing its age now after being outside all the time.
Car does run & drives, but the engine does need a rebuild. Stock bottom end with 400+ passes on it. The carpet does have four small cutouts where a 6 point cage once was. Bolt in, no welding was done.
Parts / Mods:
Factory Ram-Air hood & air box
Descreened MAF
Fernco Coupling
TB bypass
160 t-stat
Arizona Speed & Marine Monoblade throttle body
Ported Intake manifold
32# SVO injectors
Adjustable fuel pressure regulator
Comp Cams 1.52:1 roller rockers
ARP 7/16 rocker studs
GM Bowtie guideplates
ARP head bolts
Ported factory heads
Manley stainless valves (stock diameters)
Crane springs
Titanium retainers
Hardened pushrods
Comp R lifters
Comp Cam 242/252 .594/.594 108LSA
Rollmaster double row timing set
Melling oil pump
Meziere water pump
Taylor plug wires (over VC)
Hooker Super Comp headers
Mufflex y-pipe
Bassani stainless cat-back
4l60E trans built, will need to be gone through since it’s been sitting idle
Yank 4800 UT stall
Deralle deep pan with built in cooling tubes
Carbon fiber driveshaft
BMR driveshaft safety hoop
BMR tubular lower A-arms
BMR K-member
BMR subframe connectors – welded
G2 LCA’s
BMR LCA relocation brackets
BMR adjustable panhard rod
Hal adjustable rear shocks
Racetronics fuel pump & wiring harness
All I can remember for now. If there’s more I’ll update.
I purchased a few items last summer when I was going to rebuild the engine and bring it back to more of a street car. They’re listed below and go with the car:
LT1 block std bore, been tanked, ready to machine
Set of JE forged .030 flat top ultra light pistons. Pistons are in great shape with one season of short track time.
6” light weight connecting rods. Bought with the pistons above.
NIB Eagle crank, cast
Everything above goes for $4,000. Will NOT part out.
If I had the time I would part out and make more than $4K, LOL!
Car is located in Baton Rouge, LA.
Thanks,
Steve...
http://img340.imageshack.us/img340/8403/louisiana507051kj1.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507051kj1.jpg)
http://img340.imageshack.us/img340/204/louisiana507050uu3.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507050uu3.jpg)
http://img340.imageshack.us/img340/8389/louisiana507044cc0.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507044cc0.jpg)
http://img340.imageshack.us/img340/493/louisiana507037tn2.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507037tn2.jpg)
http://img340.imageshack.us/img340/7172/louisiana507036aw7.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507036aw7.jpg)
http://img340.imageshack.us/img340/9747/louisiana507038oz8.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507038oz8.jpg)
http://img340.imageshack.us/img340/4633/louisiana507052el5.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507052el5.jpg)
http://img340.imageshack.us/img340/107/louisiana507043lg9.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507043lg9.jpg)
http://img340.imageshack.us/img340/6966/louisiana507042hv8.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507042hv8.jpg)
http://img340.imageshack.us/img340/5348/louisiana507054mh7.th.jpg (http://img340.imageshack.us/my.php?image=louisiana507054mh7.jpg)
Parts / Mods:
Descreened MAF
Fernco Coupling
TB bypass
160 t-stat
32# SVO injectors
ARP head bolts
Crane springs
Titanium retainers
Hardened pushrods
Comp R lifters
Melling oil pump
Meziere water pump
Mufflex y-pipe
Yank 4800 UT stall
BMR K-member
G2 LCA’s
Thanks,
Steve...
