What is the max h.p. on stock fuel pump?
GONEB4U
11-25-2002, 11:01 PM
I just wanted know what is the max h.p. I can go with the 99 factory pump.Can I spray 100-150 hp kit on a stock pump?What is the max amount of spray that I can go on the stock pump and a stock bottom end?If not than should I upgrade to a walbro 340?
chesee48
11-26-2002, 02:36 AM
most people will say 150.. some 125..however even at 100, im gonna do a fuel pump...i say why riskit? esp if u want to spray a bogger shot down the road...then you'll already be set!
T/A lt1
11-26-2002, 09:08 AM
I put down 420 to the wheels with the converter unlocked on the dyno so I would say 125 no problem and 150 just be careful. I spray 150 with the stock pump but will be upgrading to a Walbro soon. It depends on what power you are making N/A too. If you were making 400rwhp N/A I wouldn't even spray a 100 shot with the stock pump get the drift. I only put 325 down on motor so I can get away with a nice shot.
chesee48
11-26-2002, 01:53 PM
well put TA...
good luck bro...but i'd invest in a pump..an inline is cheap to install while a intank is obviously more...try 5x more =)
i have a brand new walbro..that i cant afford to install...so i might sell it..email if u want it
good luck..i cant wait to try out the n20 :p
gb95zconv
11-26-2002, 02:48 PM
On the safe side ...100 shot. I would go no higher than a 125hp shot ....just make sure you have a fpss.
GONEB4U
11-27-2002, 12:41 AM
I'll probably go with the venom 1000 kit so I dont think I'll need a fpss.Hey chesee48 I'll send you an e-mail.
K!D
12-01-2002, 09:37 PM
Damn... So I guess I can't spray a 100shot:mad: Where can I find a fuel pump?
Thanks,
Alex
Ed Blown Vert
12-01-2002, 11:28 PM
I would say 100 to be safe. I have ran 150 with no problems.
A/F was fine.
