FireChicken1995
04-25-2007, 05:55 AM
thinking about going with the Eboost controller/gauge. anyone use this on a turbo application? i was woundering how it worked do i leave the spring in the wastegate or remove it? is it worth the cash? thanks
eboost users step inside.FireChicken1995 04-25-2007, 05:55 AM thinking about going with the Eboost controller/gauge. anyone use this on a turbo application? i was woundering how it worked do i leave the spring in the wastegate or remove it? is it worth the cash? thanks leadfoot94 04-25-2007, 10:57 AM I'm pretty sure that you leave it in. Just in case that if the boost controller stopped working, the wastegate would still actuate at the selected spring pressure. | ||
