for sale off a 95 trans am
bdc95ta
04-23-2007, 06:37 PM
Pic's at: http://s169.photobucket.com/albums/u212/bdc95ta/?start=20
Die hard battery for LT1
Stock oil pan
Stock rockers
New custom K&N cone filter flows 1300cfms
Spider tray
Stock Reverse flow coolant lines
Aluminum Panhard Bar w/ 3/4 QA1 rod ends and rod end reducer bushings. Only thing you need is spacers and your set.
Stock Plastic steering cover
MAP Sensor
Fuel line cover off a V6 camaro/firebird
New antenna for a power motor radio
EGR valve
EGR solinoid
EVAP solinoid
Air Pump
New fitting for oil pressure sensor
Stock lifter's w/ roughly 75k on them
(2) 180* Themostats
Stock air intake w/ K&N filter
New (thinner casting STOCK REPLACEMENT) Melling oil pump part #: M55HV
Make me some offer's guys if you need any other misc parts ask me I might have it. If I can't get rid of this stuff it will go in the trash.
-brandon
shaneatlh
04-28-2007, 02:49 AM
pm sent
