cmzfly93
04-20-2007, 04:37 AM
Hello,
I have a 1993 camaro 6 speed all stock w/ait p1sc 8psi 2 core kit on it. I am building motor 355 forged 8.9 compression trick flow heads blower cam. I want to make around 475 to 500 hp at tires. Turning 6000 to 6300 rpm and 10-11psi. I want to know if someone can tell me to use the egr. Right now i am not using a fmu and running an 2 bar map sensor. I want to go back to a bar system w/mad z28 tunning run close to stock timing and have an fmu so i can tune with a wideband to dial in air fuel ratio. I have 42lbs injectors and i live in iowa kinda hard to find a chassis dyno around here and find someone to burn chips. What do you guys think of running close to stock timing with only 10 psi and 8.9 compression and egr with or without air pump is currently not there.
ryan
ryan
