Put my Spec 2 in and....
WSUFlyer
04-19-2007, 07:08 PM
I installed a Spec Stage 2 clutch and Pro 5.0 shifter in my 95 Z last week...everything works good, no slipping, no noises, and no vibration. I am wondering about the feel of the pedal. I went from a stock replacement clutch to this spec 2, and it seems that the pedal is actually lighter....mostly at the bottom part of the travel. Also it seems that the clutch fulling engages a little higher than my last clutch. Like I said I'm not having ANY problems with slippage....just mostly not much slipping and a higher than I would expect full engage.
Input?
Bayer-Z28
04-20-2007, 02:52 AM
I asked a similar Q on LS1tech after my McLeod single install. I guess it's normal.
Mine fully engages twords the top of the pedal throw too, but it's considerably heavier than the stocker.
The LS7 Clutch is WICKED light too, FWIW.
