a scanner question
football4life
04-19-2007, 06:12 PM
i got an obd2 scanner and a 95'z with the 16 bit connector but it needs the obd1 is there neway i can use the obd2
2001NBMZ28
04-19-2007, 06:26 PM
If I'm not mistaken the '95 is OBDI with the OBDII port - so you need an OBDI scanner with a cable that'll connect to your 16 pin (OBDII) port. If you have an OBDI scanner you can jumper the pins to make it work on the OBDII port, but not vice versa. Am I making sense?
football4life
04-19-2007, 06:57 PM
ok i got u if i want to connect to a obd1 which pins do i use
Injuneer
04-19-2007, 07:02 PM
Some OBD-I scanners will come with an adapter to connect the 12-pin scanner connector to the 1995 16-pin connector. If you don't have an adapter, use jumpers as shown in Shoebox's link:
http://shbox.com/1/xraycable.jpg
seawolf06
04-23-2007, 04:15 PM
Once again Shoebox saves the day via Injuneer! (or is it vice versa???) :)
Injuneer
04-23-2007, 07:01 PM
Shoebox has the brains... I just point people in the right direction :D
