james_8997
04-18-2007, 09:02 AM
im buildin a 383 and tha machine shop needs a piston to bore out the block(i guess to make sure they fit perfict) now im not buyin a whole rotating assm.(trin to save a few bucks) anyways, i found these at summit racing . will they work wit a 3.750 stroke and 5.7 in. rod? im just trin to aviod a costly mistake.
http://store.summitracing.com/partdetail.asp?part=TRW%2DL2491F60&view=1&N=700+150+
gex598
04-18-2007, 09:33 AM
Those are a .060 over piston for a 383 you need a .030. Why reuse the stock rods, you can p/u eagle or scat stuff for less then $200. Plus now you have to pay to get everything balanced vs buying a balanced kit.
james_8997
04-19-2007, 10:08 AM
no the block was bored over .40 already tha machice shop says it has to be bored .60 over. im not reusein stock anything. will they work?
rskrause
04-19-2007, 10:15 AM
What makes you think the $200 rods are better than the stockers? They aren't.
Rich
gex598
04-19-2007, 10:23 AM
But the do come in a balanced kit vs balancing the stock ones.
james_8997
04-19-2007, 11:21 AM
so the stock rods will handle what im bout to throw at them?(500hp, 7000rpm, 300 shot n2o) other then that will those pistons work?
rskrause
04-19-2007, 05:41 PM
500hp motor + a 300hp nitrous shot? Everything better be of top quality. Forget stock rods or $200 imports.
Rich
Injuneer
04-19-2007, 05:43 PM
No, the stock rods will not handle 800 HP. With that large a shot (basically what I am running) you need a piston specifically made for nitrous, and rods a lot beefier that what you get for $200. And don't forget a high quality crank for your 388.
Might have been a good idea to mention the 300-shot in the original post.
Sort of a contradiction, on an engine that's supposed to support 800HP.
irocbsa
04-19-2007, 09:12 PM
I think you need to step back, hold off on the build, and do a little research. It could save you thousands in the future. Ask a few questions around here, learn who to listen to, read a few books, and go from there.
383TransAm
04-27-2007, 02:37 PM
Buy a Kit!!
Forged Pistons, H-Beam Rods and a quality crank will hande 800 HP easy.
