Adjusting Steering rack preload
Old Apr 17, 2007 | 11:37 PM
TobyZ28's Avatar
I found this thread while searching:
http://web.camaross.com/forums/showt...=steering+rack
It also references this diagram: http://shbox.com/1/4th_gen_tech2.html#rack_preload
What does adjusting the preload do? Will/can this eliminate my steering rack "play"?
Anyone able to enlighten me?
Old Apr 18, 2007 | 09:11 AM
OBE1 95Z28's Avatar
It will not get rid of play, it increases the resistance of the steering wheel causing it to be harder to turn and return. Common sources for steering wheel play are the rag joint, worn tie rod ends and play in the rack and pinion.
Old Apr 18, 2007 | 12:19 PM
TobyZ28's Avatar
Yea my rag joint looks fine, and my rod ends are new. Its definatly my R&P
Old Apr 18, 2007 | 02:42 PM
OBE1 95Z28's Avatar
I replaced my steering rack a couple of years ago. Not a big deal and not that expensive.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
95craz28
11
Sep 12, 2015 07:47 AM
rideordie
Sep 7, 2015 08:22 AM
Aug 24, 2015 06:41 AM
