2nd Thoughts About My Tune
turnin20s
04-17-2007, 08:04 PM
I sent my PCM to madZ28.com to get tuned and I left the carbon canister, but disabled everything else and I also left the rev limiter, idle speed, & shift points up to him. What is he going to set them at? I can still change them, but I wasn't sure what I should put them at and what he will put them at.
I thought he would put them in the right spots, but now I'm having second thoughts. If I redo my sheet where should I set my RPMs?
I was thinking...
Rev Limiter-6500
Shift points-5800
Idle-750
Mods are in my sig and my heads are like a LE2.5 as far as flow goes
infinitebird
04-18-2007, 10:32 AM
I would definitely shift higher than 5800 with the cc306 as long as your valvetrain is setup right.
96flame
04-18-2007, 08:33 PM
With a built bottom end, ported heads and 306 cam you'll wanna shift at least 6500 if not higher. It won't idle very well that low either 850-900.
turnin20s
04-19-2007, 10:45 AM
Well its a little later right now, but I'll wait and see what Ion does. If I don't like it I can always have it retuned, and I was planning a dyno tune as soon as I have the money anyway.
SABLT194
04-20-2007, 03:48 AM
You'll need more idle for sure. 750 on a cc306 won't cut it
turnin20s
04-20-2007, 08:51 AM
I was just guessing. I'm letting him decide where to set everything now.
Does anyone have any idea where he will set shift points, rev limiter, and idle? Or do I have to wait and get it to see for sure?
unforgiven
04-21-2007, 04:16 AM
Why don't you ask him?
turnin20s
04-21-2007, 06:25 AM
Because it takes about 3-4 days to hear back from him and my PCM will be back by then
