T56 Tranny Fluid?
93Phoenix
04-17-2007, 12:39 AM
I have read to use 4 quarts of Dexron III ATF. A friend insists not to use Dexron entirely, because it's thin, and if I put some lucas 80-90 gear lube mixed with lucas tranny fluid it would be smoother? Thoughts?
CrazyLT1
04-17-2007, 05:50 AM
Dextron III ATF seems to be what MOST people on here use
I personally use Royal Purple and LOVE it
shoebox
04-17-2007, 08:19 AM
You are not supposed to put gear lube in it.
OBE1 95Z28
04-17-2007, 10:37 AM
151K miles on my original T56 tranny with Dexron III, no issues.
Capn Pete
04-17-2007, 11:07 AM
If it calls for Dexron III, then run Dexron III :rolleyes:.
Who is your friend, and what does he know????? :confused: :p
If you're really concerned, you can run a synthetic ATF (although it's really NOT "necessary") or you can buy, DIRECT FROM GM, their "synchro-mesh" fluid. But DON'T run "gear oil" :no:.
93Phoenix
04-18-2007, 02:37 AM
Well he is a Ford guy if that tells you anything.;)
It sounded fishy to me. Thanks guys.
