How can I correct this?
Old Apr 15, 2007 | 01:41 PM
CamaroUK's Avatar
I just noticed that my front drivers side tyre is worn smooth at the edge, what do I need to do to adjust to correct this?:
There is 6mm of tread in the middle of the tyre, and the other side of the tyre is fine. All the other tyres are in perfect shape.
Old Apr 15, 2007 | 01:45 PM
mdacton's Avatar
get a front end alignment
mrr23's Avatar
normal wear for 4th gens. it's due to having positive camber. setting the camber to -0.50 will aide in controlling this wear.
Old Apr 15, 2007 | 01:58 PM
CamaroUK's Avatar
Is this something I should attempt myself or would I be better off getting a garage to do it?
Old Apr 15, 2007 | 02:00 PM
mrr23's Avatar
have a shop do it
Old Apr 15, 2007 | 02:19 PM
mdacton's Avatar
Originally Posted by mrr23
have a shop do it
for sure.....they can check it on a front end machine
Old Apr 15, 2007 | 09:21 PM
Z-RATED94's Avatar
Did you not catch the part where the other front tire is not wearing out the same way?
Old Apr 15, 2007 | 09:23 PM
mrr23's Avatar
yeah i did. i own an alignment shop, so i feel i have some knowledge in this situation.
if you want me to get deeper into diagnosing it, here goes.
with the particular tire wear he is having, it would indicate to me there is excessive positive camber on the left with possible excessive positive toe and caster lower on the left. this would indicate a pull to the left as well.
without having the car in my shop and on my alignment machine, it is a guess at best.
Aaront810
Aug 29, 2020 09:34 PM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
