LT1 block prep
95ttoplt1
04-14-2007, 02:25 PM
Hey guys I am building a 370 LT1, max rpm of ~8500, All-Pro heads, Shaft mounts single plain, cola crank, Eagle 4340 rods(L19) yada yada yada..It will also have a lot of nitrous used as well
My question is what all should I do to the block? I wanna keep this as affordable as I can, but I want it done right.
I have looked at site like these and they all offer pretty much the same service but the prices are drastically different.
http://www.sehrpower.com/blockprep.htm
http://www.cncblocksnortheast.com/
Is any of the lifter and cam truing gonna get me any where or am I just wasting money?.
Also I am going to do a half fill, is that something I can do myself? Should this be done before or after machining?
Should I run roller cam bearings or stay with the stock style?
I am planning on putting the debris screens and stand pipes in the lifter valley and of course 4 bolt splayed billet caps. Should I get billet #1 and #5 caps as well? What about a stud girdle?
I am planing a DCR right around 9.1 and around 3-400hp of nitrous(with race gas of course). Can a cometic seal all of this or should I O-ring and use a copper shim??
What other areas should I look into to prolong the life of this thing??
Thanks for your time, any and all info is appreciated.
n20ta2
04-14-2007, 04:16 PM
I wouldnt waste my money on that for a fairly budget build but you should get the block decked for sure and have the block tanked before the fill and fill it before machining. I dont know about everyone else but I have sprayed 300 on a cometic with no issues.I dont know how much is gained by running roller cam bearings but I do know that there are some insainly quick cars out there running non roller bearings so for the price I dont know if there worth it
95ttoplt1
04-14-2007, 04:21 PM
Great, thanks for the info. Is there a special Cometic or are they are the same??
I think I can run a Bigger diameter cam if I do the roller bearings, is this true??
1racerdude
04-14-2007, 04:31 PM
It will cost ya about 500.00 to do the roller cam bearings.
The factory installs the cam bearings and then line bores them. Don't think your local shop can do it. The truing is worth it in the block.
95ttoplt1
04-14-2007, 06:16 PM
Truing the cam bore, or getting the roller bearings installed seems to be the same price so that kinda makes that one easy.
Is there any disadvantages to the roller cam bearings other than cost??
This will be a limited street engine.
rskrause
04-15-2007, 12:46 AM
Is any of the lifter and cam truing gonna get me any where or am I just wasting money?. Should I run roller cam bearings or stay with the stock style?
By the time you do this kind of work, you may as well can the LT1 and get an aftermarket (Dart) block, Gen I style. You are talking about ~$3,000 or so in block prep if you include 4-bolt mains.
Before. It's not hard to do, but done wrong will ruin the block.
You don't need a stud girdle. The other stuff is needed to run 3-400hp nitrous on a small block.
Talk to Cometic, but I think it would work. As I stated above, the LT1 is not a logical starting place for a max effort build. You will be limited wrt head and intake choices unless you start adapting stuff, in which case why bother with the LT1 in the first place.
Rich
95ttoplt1
04-15-2007, 04:03 AM
Rich
Thanks Rich.
I know the LT1 isn't a good starting point but I already have Converted All-pro 227's(CNC'ed to 255), converted intake, one piece crank, DFI for the LT1 ect ect so I'm kinda in to deep to turn around now LOL
I saw a write up somewhere about a "strap" on the number 5 main, between the cap and pump. What does this do and would my application benefit from it??
Any other areas of concern on the LT1 block for the abuse I have planned??
I know it doesn't make sense to build an LT1 but I'm just too far along to bail now.
Troy
1racerdude
04-16-2007, 07:14 PM
If ya put in the rollers ya will have to get another cam.
If ya have a 4 bolt block use Program 3 center caps and ARP studs. If ya got a 2 bolt dot't try to build it.
95ttoplt1
04-17-2007, 01:57 AM
I don't have the cam yet so that shouldn't be a problem, but you lost me on the block.
Are you saying to only use a 4 bolt block and not to convert a 2 bolt?? I have heard mostly the exact opposite of this. Can you explain? I was going to have a 2 bolt converted to splayed 4 bolts as I thought this was stronger??
1racerdude
04-17-2007, 01:10 PM
The difference between straight and splayed has been in debate for years.
I didn't know ya were going to convert a block.
95ttoplt1
04-17-2007, 01:37 PM
Ah ok, yeah a set of 2 bolt main would be rather short lived in my application:D
I talked to a couple different builders(VRE,Golen) about block options and all seemed to recommend a splayed billet cap.
1racerdude
04-17-2007, 01:48 PM
:thumb:
SStrokerAce
04-19-2007, 01:03 AM
CNC Blocks NE is very good. In fact for what you are doing that's a place I would recomend. I've had blocks from Carl and they are excellent.
I wouldn't try to do what you are doing without the lifter and bore true. I would also hard block and do a center 3 4 bolt conversion. You can strap the rear cap and run a new front cap as well if need be
Bret
95ttoplt1
04-19-2007, 03:15 AM
Thanks alot Bret, I guess I will just have to save a little more money.
I was looking at The Pro-Gram and Callies caps.Callies offers a full set(all 5 caps) and straps for less than 600, so I think I will get the caps from Callies at least, but I still kinda want a stud girdle, just for peace of mind really if nothing else.
Does anyone know who makes a good stud girlde for the SBC? I can only find the ebay ones.
SStrokerAce
04-19-2007, 01:00 PM
I would let whoever is doing the work to put the caps on choose.
Don't put a stud girdle on a SBC if you can help it.
95ttoplt1
04-19-2007, 01:59 PM
No stud girdle, really?? I guess I have been hanging around my brothers too much, they run SBF's and they seem to always run a girdle.
Does a girdle weaken the SBC or is it just more hassle and no gain??
Thanks again for the input.
OldSStroker
04-19-2007, 02:17 PM
LOL!
"If you have a nice bottom end, you don't need a girdle." ...told to me by a wise man who wasn't a gearhead :)
SStrokerAce
04-20-2007, 01:04 PM
Well a SBC was made to run 4 bolt mains, and 302/5.0L SBF's where not. So they came up with a crutch to try and help that block. The Cleveland on the other hand is a different story, that is probably the best designed motor from the 60's. It's evident that it's architecture is copied by GM, Toyota and Dodge in their top tier NASCAR motors today.
Bret
95ttoplt1
04-20-2007, 01:47 PM
Bret
Ok thanks, and yes the Clevelands are sweet, we had a 4 barrel cleveland in a mustang and it was alot of fun and pretty quick.
