leadfoot94
04-12-2007, 12:45 PM
I was wondering if anyone has had any problems with the rubber grommet (that holds the IAT sensor) blowing out under boost?
Anybody use a Trickflow Elbow?leadfoot94 04-12-2007, 12:45 PM I was wondering if anyone has had any problems with the rubber grommet (that holds the IAT sensor) blowing out under boost? blown383 04-12-2007, 12:49 PM Im wondering the same thing. -B ZBLKHELLRZR 04-12-2007, 01:12 PM Wish I could answer that question for you but I'm still not up and running. Maybe CALL911 or someone else can post a response. Silas, Ponyhntr 04-12-2007, 02:09 PM I had one on my car, but I was only running about 5-6 psi of boost. Never had any troubles. I'm going to be running the ATI elbow now with my new setup. NJ-LE 04-12-2007, 04:15 PM I used a small amount of silicone glue and 3 narrow tie wraps. One short one around the sensor and two long ones through the small one on either side and tightly around the elbow to leash the IAT to it. markinkc69z 04-12-2007, 08:36 PM I don't know of anyone under at least 15 psi that has ever had trouble. Keep in mind that the hole size isn't very large so boost pressure doesn't have much area to push against. | ||
