Turbo cam
detroit1994z28
04-10-2007, 03:24 PM
Someone in my area is selling a brand new custom grind cam that was desinged for a supercharged application. I have a turbocharger. Would this cam still work good - Better then the hotcam. Also given these specs would it have a lopey idle to it??
gross lift .572in .585exh
dur @.006 tappet lift 288int 292exh
dur @ .050 236int 242 exh
lobe seperation is 114
engineermike
04-10-2007, 11:57 PM
Need spec's on engine and turbo.
detroit1994z28
04-11-2007, 01:06 AM
Engine is basically all stock with stock aluminum heads 1:6 rockers the turbo is a sts system t-67 upgrade
engineermike
04-11-2007, 07:12 AM
There is nothing particularly wrong with that cam for turbo use, but it's overkill on a stock engine with a little turbo. Engine and turbo will be signing off when the cam comes into power.
