suspension install
Old Apr 7, 2007 | 04:46 PM
noregretz999's Avatar
suspension install
Will having no motor or tranny in the car at the time of the install affect anything when installing a moser rear, cross brace mounted torque arm, rear sway bar, and rear LCAs? If so, should I wait until I have the motor and tranny in to install them?
Old Apr 8, 2007 | 08:50 PM
Severous01's Avatar
wait until the suspension is loaded to tighten everything down. that's all.
you can put it in and do whatever you want, but loosen then tighten once everything is in place. especially with the control arms. you'll bust the rubber or poly in the arms if you do this wrong. premature breakdown.
other than the arms, the torque arm shoudl be fine...no problems there, as well as the springs/brakes/other misc stuff.
Nov 18, 2023 07:21 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
