8.19 in the 1/8th plus a 150 or 200 shot
Old Apr 7, 2007 | 09:48 AM
axehead's Avatar
i ran 8.19 with 83mph in the 1/8th on motor, what do you think i could achieve with a 150 or 200 shot?
Old Apr 8, 2007 | 10:02 AM
axehead's Avatar
any comments would be appreciated
Old Apr 8, 2007 | 12:33 PM
Daniel6718's Avatar
7.50
Old Apr 8, 2007 | 12:40 PM
396D1SS's Avatar
I say with a 150 shot 6.9's 7.0's with a good launch if your running 8.10's right now
Old Apr 8, 2007 | 12:44 PM
danhr's Avatar
I'd say a mid 7.
Old Apr 8, 2007 | 08:47 PM
396D1SS's Avatar
Originally Posted by danhr
I'd say a mid 7.
Maybe in your air..My old tnt f2 kit knocked me down a bit
Old Apr 8, 2007 | 08:52 PM
396D1SS's Avatar
but we all know how tnt rates their kits :/
Old Apr 8, 2007 | 08:57 PM
kline454's Avatar
well if it was my car it would run a 8.50, haha got to love no traction.
Old Apr 8, 2007 | 09:16 PM
danhr's Avatar
I'd like to see a timeslip. I am calling bs.... I have my doubts that a 150 shot will drop a high 12 sec car into a high 10 sec car....
Old Apr 8, 2007 | 10:02 PM
AZ2ENVY's Avatar
I wouldnt be so quick to call bs . I have personally seen a 94 Z28
with a Moroso cold air , unhooked exhaust from cat , 125 dry shot ,
and street tires put that Z from a 15.1 1/4 to a 12.9 1/4 . And
that was at 6000 Ft. Elev .
Old Apr 8, 2007 | 10:15 PM
danhr's Avatar
maybe i'm just being close minded then.... the 15.1 to 12.9 time seems reasonable. but a 150 shot shaving off two seconds on the 1/4 miles seems pretty iffy to me. Considering most people who run bolt ons + 150 run low 11's at best, usually around mid 11's.
Old Apr 8, 2007 | 10:24 PM
AZ2ENVY's Avatar
Very true considering the lower times you get into the harder it is to
shave off more time . I would personally say with a 150 shot he will
be around the 11.0-11.5 area
Old Apr 8, 2007 | 10:34 PM
danhr's Avatar
i take my comment back... i just searched the guy's posts and found his mods
my car is a black 93 with m6 & has lt4 hotcam with pcm4less tuning, stock home ported heads by jordon musser, stock short block, 52mm tb, underdrive pulleys, tb bypass, hooker lt's, no cat, borla catback, ewp, msd digital-6 plus, b&m ripper, moser 12bolt w/4.11's, bmr ta, mt et street radials.
I was under the impression it was a bolt-on car.... 6.9s are def. doable
Old Apr 9, 2007 | 11:34 AM
Ray@NitroDaves's Avatar
if the car runs 8.1's in the 1/8th it will not run 10's on a 150 shot..
it will probably pick up .4-.6 in the 1/8th depending on traction.
a 150 shot on my car took me...
from 7.24 to 6.69 (1.60 to 1.49 60')
another day 7.40 to 6.96 (1.64 to 1.55 60')
you are probably looking at the 7.4 to 7.7 range depending on traction....if it spins bad it could be a 8.50
ImNraged
Aug 19, 2018 08:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
NewsBot
Aug 3, 2015 02:40 PM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
