Suggestions for Fuel Filters on my LT1
HectorM52
04-06-2007, 12:06 PM
Okay, I've searched and I haven't found the exact answers I'm looking for.
Also, please don't just throw out a part number because you saw it on Jegs or Summit. I need a suggestion with reasoning behind it...
WHICH FUEL FILTERS DO YOU GUYS SUGGEST???
I've got a 20-gallon fuel cell in the back, it has -10AN fittings. I plan to run typical FI rubber hose, double clamped at the fittings. I plan to have a filter between the cell & pump as well as after the pump. I have a Walbro pump. I plan to stay with 3/8" supply & 5/16" return.
I've also seen 20-micron filters all the way up to 100-micron filters. Obviously the smaller ones filter out smaller particles. But what is "necessary" for our motors?
Thanks for the help and if I can add more info to better help you guys, let me know.
