CamaroRacing12
04-02-2007, 10:27 PM
do u really need a lift to SAFELY install longtubes? i want to install my longtubes and dont know really how high im gonna need to get the car.... any input would be nice.... also wat 02 sensors and extensions do i need to buy?
95LT1conv
04-02-2007, 10:37 PM
you dont NEED a lift. i had the front at about 2.5'. just get a good set of jackstands all around and you'll be fine. i've also heard that if you pull the valve covers, both sides can go in through the top
reamo04
04-02-2007, 11:03 PM
we did it with jackstands all around. Driverside from the bottom, passenger side from the top.
buy o2 extensions from thunderracing.com
2000GTP
04-03-2007, 08:44 AM
You have to get the car up very high in order to get them in. Just make sure the car is safely supported on jackstands, safety is key. I would stick with AC Delco sensors and 12" extensions should do the trick as well. If your headers are coated, I would drive around with the old sensors for at least a week and break them in. Then put in the brand new sensors. You can probably snag the sensors from one of these guys for a really good rate: http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
