Which O2 extensions do I need for longtubes
Z28Roxy
04-01-2007, 05:08 PM
1995 CA A4, has dual cats, OBD1, and two O2 sensors.
What pin style connection and length do I need to get? I'm going to do Pacesetter LTs.
2000GTP
04-01-2007, 05:20 PM
You'll need the flat connectors. The 12" length did the trick for me.
CamaroRacing12
04-01-2007, 11:19 PM
the o2 sensors that r in the stock manifolds are right next to ur valve covers right? they r that weird thing sticking into the manifold right? lol just wanna get things clear lol.... also wat size are the stock header bolts?
6SpdLT1Z
04-02-2007, 03:26 AM
I think that's OBD-II, isn't OBDI square?
I went with 24" and I'm just going to ziptie them to play it safe.
2000GTP
04-02-2007, 12:45 PM
The flat connectors are for the front 02 sensors, the square connectors would be for the rear 02 sensors which are on the OBD-II f-bodies.
6SpdLT1Z
04-02-2007, 04:41 PM
The flat connectors are for the front 02 sensors, the square connectors would be for the rear 02 sensors which are on the OBD-II f-bodies.ah, I'm running no cat so I'm deleting that O2.
2000GTP
04-02-2007, 04:43 PM
Yep, in that case, either PCM tuning or the plug in 02 simulators, which happen to be the square connectors, will do the trick.
AmericanMuscle33
04-05-2007, 09:39 PM
Is it possible just to splice in 12 inches of extra wire into the O2 sensor harness? or is this a no-no and can screw up the signal?
2000GTP
04-06-2007, 12:16 PM
You can splice the harnesses, but it really is not a good idea. It has been shown to create problems.
