Vibration
Old Mar 30, 2007 | 11:13 PM
hashimsaleh's Avatar
Vibration
i have a 1995 camaro Lt1 m6
so latly i get this crazy vibration from under my car at high speeds ?? only at high speeds ? and then it kinda limits me from going any faster ! what could that be from ?
any info would be Great
Old Mar 30, 2007 | 11:15 PM
Angelis83LT's Avatar
tire balance possibly?
Old Mar 30, 2007 | 11:16 PM
no i don't know its coming from right under me like the drive shaft is vibrating or something ?
Old Mar 30, 2007 | 11:20 PM
maybe a trans mount or torque arm? but those ussually happen only when you accelerate.... Could be something with the clutch. My t-5 shook pretty good and then I changed the clutch/preassure plate/flywheel and It stopped... so not sure which one was making it shake. When I change the one on my other car I will let you know if anything is strange with it. because it shakes some too. hmmm.. not to much it could be rreally. it is either in the balance of tires, or in the drivetrain. (I suppose it could be in the suspension, but if your wheel is not bouncing any then it would not be in the front end.)
Old Mar 31, 2007 | 03:44 AM
Dave89IROC's Avatar
how fast?
Old Mar 31, 2007 | 10:34 AM
85- 90 mph it vibrates like crazy !
Old Mar 31, 2007 | 11:44 AM
Dave89IROC's Avatar
driveshaft is out of balance
since you are in Windsor, if there are no places over there that balance driveshafts, there are a couple over here, one is Arrow Truck, just off the Ambassador Bridge
you would need to remove the shaft and bring it over, depending on when you drop it off, it may take till the next day
Old Mar 31, 2007 | 11:45 AM
so is it better to replace or just to balance it ? if i do replace do they balance it ?
Old Mar 31, 2007 | 11:49 AM
Dave89IROC's Avatar
up to you on rebalance/replace
if you get a new shaft, it will be balanced(a used shaft might be out, but if you get a used shaft cheap, you could take it and have it balanced)
while out, might be good to check the u-joints(for play and for sticking)
if you go to Arrow, they can replace the joints as well(if needed) their prices for these things are pretty reasonable
Old Mar 31, 2007 | 11:50 AM
oh alright thanks now i've been looken around
and some shaft comes 2 pieces and some come one ? which one is better i have a 1995 camaro lt1 m6
Old Mar 31, 2007 | 11:55 AM
Dave89IROC's Avatar
you have(and will want) a 1 piece shaft, the 2 piece shaft come on the v6 cars
Old Mar 31, 2007 | 11:57 AM
thanks for the help bro you know anywhere to get a good idea on one ?
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
