99TransAmWS6
03-30-2007, 10:31 AM
I just recently installed a new headlight motor in my passenger side headlight. I changed it because it wouldnt go up or down unless i manually did it. Even with the new headlight motor it still wont work! I have no idea what to do next. Anyone have this problem before or have any suggestions? HELP!!
popstoy
04-01-2007, 03:15 PM
check fuses ,relays,and wireing going into headlight switch
fergymoto
04-04-2007, 02:28 AM
I have the same problem with my '95 vert right now. It is not the motor, and it is not the headlight motor control module. I have swapped both out with working ones from my WS6 to diagnose. No luck. I have not tried following the wiring yet. Keep us posted!
transAMdriv3r
04-06-2007, 07:20 PM
check the relays in the fuse box under the hood
99TransAmWS6
04-06-2007, 08:00 PM
ive checked all fuses. and even what they call the "guide module" i was looking threw my GM Service manuals and saw it. Its all good. It has to be a wire crimped,cut, somewhere....greaat!
