STAYBG87Z
03-27-2007, 11:29 PM
i need a list of everything ill need to install these.like o2 sims,tuning,what?i need to see how much $$$$$$ ill need to make the install complete,so i can do it in one shot.thanks.oh its a 96z m6. and im keeping the emissions hookups except cats.
Eric@Victory Racing
03-28-2007, 07:00 PM
Headers, Exhaust Gaskets, O2 Extensions.
CamaroRacing12
03-28-2007, 10:08 PM
i thought the headers came with copper gaskets??.... also what about header bolts?
STAYBG87Z
03-28-2007, 10:49 PM
so if i delete the cats do i need o2 sims?
6SpdLT1Z
03-29-2007, 04:37 AM
so if i delete the cats do i need o2 sims?yes, or have them tuned out via the PCM.
Your going to need: Headers, ORY (or Y w/ Cats), Header Gaskets, Collector Gaskets, Header Bolts, Collector Bolts, Plugs/Wires (I suggust changing them while your in there), o2 extensions, o2 sims, and you may want to change the o2's while your at it.
2000GTP
03-29-2007, 12:38 PM
Here is a list of what I used for my install:
ARP bolts
Fel-Pro gaskets (won't apply to you if your headers came with copper gasket)
2 12" 02 extensions
2 O2 simulators
A couple cans of PB blaster, shop rags, cable ties, ect
OTVC loom kit
OTVC wire set
3" band clamps ( I used these instead of the u-clamps supplied with the kit to prevent crushing and distorting the pipes.
New plugs and 02 sensors.
Critter
03-31-2007, 10:37 PM
arp bolts, headers,copper gaskets, and ultra copper
Red Devil 99'
06-06-2008, 12:39 PM
ok this is what I have so far I hope I'm not missing anything if you see something let me know
set - Pacesetter Long Tube Headers (coated w/egr/air)
set - Pacesetter Off road Y-pipe
3 - 3" exhaust clamps
2 - hanger bolts/nuts
6 - EGR/AIR bolts
12- header bolts w/washers
2 - header gaskets
2 - air gaskets
1 - EGR gasket
2 - o2 extensions
2 - o2 sims
8 - NGK v-series (tr55)
1 - set MSD wires
1 - Bosch oil filter
1 - fuel filter
6 - Qts Castrol GTX high mile 5w-30
1 - glowshift oil filter sensor adaptor
1 - glowshift oil temp gauge w/sensor
1- -glowshift trans temp w/sensor
1 - glowshift air/fuel ratio gauge
4 - jack stands
2 - jacks
2 - work lights
2 - cans PB penetrating oil
all my tools (esp 10mm and alot of extenders as well as patience)
1 - glowshift decal
2 - pacesetter decals
2 - Hooker decals
1 - set red bawls
http://i279.photobucket.com/albums/kk144/AmericanMuscleV8/0606081244.jpg
if I should be forgetting something let me know I'm attacking this job next thursday
