TN94Z
03-21-2007, 11:16 AM
98 trans am
2000 camaro motor w/ 50,000 miles
ls6 intake
trex cam
patriot gold springs
hardened pushrods
thunder racing oil pump
asp pulley
Kooks long tubes
ported tb
85 mm delphi maf
3 inch exhaust with bullets and turndowns
4.10 gears
qa1 r series with 275 lb springs
rear qa1s
adjustable rear control arms
adjustable panhard rod
UMI K-member(new)
Lower a-arms(new)
Prothane motor mounts(New uninstalled)
Spohn Rear drag sway bar(New)
FAST Dual sensor wideband(New uninstalled)
Spohn SFCs(New uninstalled)
ARP Rod bolts(New)
drag lites 15x3.5, 15x10s, MT275/60/15.(All brand new)
th350 with trans brake and reverse manual valvebody(just gone through-0 miles)
5000 stall
6 point cage
kirkey econo drag seats
lightweight carpet
battery relocated
tuned by horsepower house in bg kentucky.
car weighs 2967 with out me in it.
The only problem with the car is that it may need a new body control module. I had a shorted wire that I think shorted out the BCM. This is a strip car. It has no heat or AC or radio, etc... Very fast. Cuts 1.5x 60fts off footbrake and has ran a best of 7.31(shifting 1k rpm early and had tranny issues). Lots of potential. Just checking to see if there is any interests. I am in no hurry to sell. I am looking to get 9.5k OBO out of it.
ls6 intake
trex cam
hardened pushrods
asp pulley
Kooks long tubes
ported tb
85 mm delphi maf
4.10 gears
rear qa1s
UMI K-member(new)
Lower a-arms(new)
ARP Rod bolts(New)
5000 stall
6 point cage
lightweight carpet
battery relocated
