What Ignition Components are worth upgrading?
1LESSZ28
03-20-2007, 11:20 AM
budget minded so nothing extravagant. just wondering if there are any benefits (mpg and/or hp) to more powerful coils, wires, ignition modules, msd 6a etc.
2000GTP
03-20-2007, 11:40 AM
On a stock or bolt-on car, plugs and wires would be as far as I would go. I wouldn't replace the coil or ICM unless necessary and I wouldn't run an ignition box unless I had the engine mods to require one.
BTC
03-20-2007, 01:01 PM
Didn't the 93-95 models have a weaker coil? I believe I'm going to change my coil when I put a new opti on, but I'm not sure whether to get a Crane or MSD. Are those comparable quality? I think there is also one made by Hypertech.
1LESSZ28
03-20-2007, 01:40 PM
Yes, the 96-97 coil is better not sure if it is plug and play though on later models (maybe other parts were upgraded on 96-97 years?).
canuck94z28
03-20-2007, 01:47 PM
I got a little better drivability and slightly better throttle response w/mine.BTW try find one used as their not worth the new price.:)
stopthatman
09-29-2007, 08:55 PM
Has anyone upgraded to the 96 coil/ICM on a 94? plug n play?
blueformula350
09-30-2007, 10:24 PM
It isnt plug and play. The plug is a different style (still 3 wire) you can order the correct plug from gm (part no. 88987992) and splice it into the harness. You also need a coil wire from a 96+ LT1.
stopthatman
10-01-2007, 02:59 AM
thanks, but damn i don't want to splice the wires. crap
