detroit1994z28
03-18-2007, 02:44 PM
I'm looking for this panel that attaches underneath the front bumper. I did this ram air scoop mod but since I no longer need it I have a huge hole and would like another cover panel to replace it - It's for a 94 z28. 93-97 models I would need. Please let me know.
http://img235.imageshack.us/img235/6853/cutoutpx4.jpg
Voridaeus
03-18-2007, 05:35 PM
Front end fascia outer deflectors can be found at www.gmpartsdirect.com:
LH GM PART # 10297291
RH GM PART # 10297290
Both pieces are $14.07 each brand new +shipping. Though not sure which is the driver's side depending on how you are facing the car when referring to it... I'm assuming left hand? Otherwise, you could order both and have a spare for the other side if it ever gets broken.
detroit1994z28
03-18-2007, 06:26 PM
I really dont remember but I thought that was one whole piece underneath the car
Voridaeus
03-19-2007, 08:08 PM
If you asked me last week I could have crawled under my '97 and peeked since it was nearing 60 degrees and sunny, but now it sits surrounded by nearly a foot of snow... thanks to the lovely weather we're having here in NY.
I can't see beyond the air dam does this part sit behind it? I saw on mine before the air dam it is 2 pieces on either side in the corners maybe that's what I was thinking of instead...
Voridaeus
03-19-2007, 08:17 PM
I searched for similar posts in which I also found this part number for a 1 piece deflector looks like it's sitting behind the air dam. Part number is 10246273 and it is listed on gmpartsdirect for $21.28.
Cannot say for certain... sorry, I could not be of more help.
pcgamer4life
03-19-2007, 08:53 PM
If I recall, it's all one piece, but it's got "cuts" in it to make it into different sections so you don't have to remove the whole thing to access the underside of the engine compartment. You simply remove 3-4 front bolts and bend down a section you need exposed.
t-bucket
09-03-2007, 06:53 PM
any one know the part number for the air dam and the peice that covers the front of radiator for highway air?
Loochy88
09-18-2007, 09:29 PM
i actually have a couple of these panels (driver's side)
if you need one, i can send pics
