30# injectors enough?
maro z28
03-17-2007, 04:01 PM
Can 30# SVO injectors properly supply fuel for this cam:236/242 .624/.576 110+4?
Looking to spin up to the low to mid 6k range. Injectors are backed by Racetronix fuel system and adj. fuel pressure regulator. Thanks!
Spitfire557
03-17-2007, 04:16 PM
I'd go for the 36# injectors with a cam that size, but my opinion isn't backed by much experience, so I'd wait for someone else to chime in also!
maro z28
03-17-2007, 05:47 PM
Which LE set up do you have? LE1? LE2? LE3? What size injectors do you have? Just curious?
jsetzer
03-22-2007, 03:20 PM
Thats a crapload of intake lift compared to the other numbers. I ran a 306 on stock injectors. 30 should be plenty.
Also you have an adjustable if you need a little extra help too.
If you are buying new, get bigger to be safer for the future. If you found a great deal take the 30s.
