pro stars on the z
red 95 z28 lt1
03-15-2007, 10:35 PM
got the fronts for now let me know what you guys think.
http://i175.photobucket.com/albums/w141/11secz28/firstpicinjeep002.jpg
red 95 z28 lt1
03-15-2007, 10:41 PM
http://i175.photobucket.com/albums/w141/11secz28/firstpicinjeep003.jpg
Jlo
03-15-2007, 10:59 PM
Looks real Goood.
Injuneer
03-15-2007, 11:20 PM
What is the wheel size, including backspace? What is the tire size?
These questions get asked here all the time, and I could put a link to the photos in the FAQ. Perhaps add a photo from the direct front, showing where the outer edge of the tire sits relative to the outside edge of the fender.
Thanks for posting.
Z-RATED94
03-16-2007, 12:15 PM
Very nice, what tires are you going to run in the back, when you pick up the rear wheels?
red 95 z28 lt1
03-16-2007, 12:17 PM
they are 15x 3.5's with a 1.75" backspace, thanks to you Injuneer i would of never figured this out i also am using a spacer as stated in the wheel and tire FAQ
Rears are comming soon!
ill get more pics up soon when i come back from colorado. I just bought a new digital camera and happend to have the camaro out that day so took 2 pics to see what it would look like on the computer.
red 95 z28 lt1
03-16-2007, 12:19 PM
as for the backs ill be running 28x10.5's et drags i think not %100 sure on that
Z-RATED94
03-16-2007, 12:21 PM
On the street, or just for the track? I'm thinking track only. :eek:
red 95 z28 lt1
03-16-2007, 12:23 PM
that is correct for the track
Chevy16
03-17-2007, 12:32 AM
those will look good
MTL_Z28
03-19-2007, 12:52 AM
I think they look really good, I sometimes wish I had got the pro stars instead of the draglites I have right now but oh well. I'm running 15x6's up front and 15x10's in the back (7.5 backspace) with 275 50 15 MT ET Street radials. I wanted something for street and track. BTW let me know how your wheels and tires fit in the back, I had to make some adjustments to make them fit (had to grind the brake calipers down a bit, grind the bump stop supports, and then adjust with my PHB).
CamaroRacing12
03-21-2007, 11:28 PM
how much did u pay for those anyways? i am currently in the market for some drag rims but cant deciede on what brand...i love the look of those prostars tho...right now they are my fav...
MTL_Z28
03-22-2007, 01:55 AM
On summitracing the Weld wheels cost between about 150$-200$ per wheel depending on the size. However summit makes imitation welds that are really inexpensive (less than 100$ per wheel) but they are only available in a limited number of sizes I think.
97BlackSSCamaro#142
03-22-2007, 08:43 PM
im gonna run weld 5-stars --15x4's on the front and 15x10's with a 295/50/15 on the back with a 1/2" spacer to get them off the caliper and bumpstop block i'll post pics when i get them on,,,should i have any problems with the back
Injuneer
03-24-2007, 01:50 PM
The Summit wheels (JEG's also has them, with their name on them) are not copies of the Pro-Stars. They are copies of the discontinued Pro-Star XP's. The XP's are a heavier 1-piece street wheel, not a drag wheel.... look the same, but that's where the similarity ends.
reamo04
03-24-2007, 02:59 PM
what is the backspace for the 15x6s up front your using?
im going to do prostars wtih
15x6 up front
15x10 in back
but i dont know what backspace i need for 15x6 up front
MTL_Z28
03-24-2007, 05:59 PM
The 15x6's are a 3.5" backspace. That's the best you can do with a 6" wide wheel. The spacing is the same as 15x10's with a 7.5" backspace except you need to run a 5/16" spacer on the front wheel, so in other words the front wheels stick out 5/16" more than the rears.
You can see pics of my fronts here:
http://web.camaross.com/forums/showthread.php?t=443043
Injuneer thanks for clearing that up about the summitracing wheels.
reamo04
03-24-2007, 06:38 PM
if i did 15x 8 up front, what backspace do i need?
reamo04
03-26-2007, 10:08 PM
anyone?
MTL_Z28
03-26-2007, 10:15 PM
8" you would need 5.5 BS, 6 or 6.5 would actually be better with the spacer in the front you will need to run (wheel will be a bit more tucked in), but I don't think they make the 15x8 wheel with that spacing.
reamo04
03-26-2007, 10:40 PM
they make a 5.5" backspace, any idea if that'd work?
MTL_Z28
03-26-2007, 10:44 PM
It would definitely work, but what I'm saying is that it might be better to go with a 6 or 6.5 inch backspace if possible so that the fronts tuck under the fender a bit more since you will have the spacer in the front that will be pushing the wheels outward a bit more than the rears.
rickssz
04-02-2007, 09:58 PM
I cant grind and fit the wheels myself so I need to know if I do the 5/16 spacer and longer studs then the grinding isnt neccessary cause if it is I might as well just pay someone to grind more and dont use the spacer and studs or else Im pay twice for the same result???
MTL_Z28
04-02-2007, 11:36 PM
Are you talking about the front or rear wheels?
The fronts require NO grinding to fit... just the wheel spacers.
rickssz
04-05-2007, 11:29 PM
Yeah I was talking fronts in either 3 1/2 or 5 or 6 inch. Probably 5 inch seems to be the best compromise.
