gillt1
03-14-2007, 07:24 AM
HI all,according to my sig would 30# injectors help with any performance gain ? Thanks In advance
30# injectorsgillt1 03-14-2007, 07:24 AM HI all,according to my sig would 30# injectors help with any performance gain ? Thanks In advance 2000GTP 03-14-2007, 03:38 PM It depends if your stock injectors are getting towards maxed out on the duty cycle. If they are, then an upgrade would be of benefit. TobyZ28 03-14-2007, 05:56 PM Your Sig: 95 z28,t-tops,K&n cai,52mmtb,lt4km,lt4cam kit,pacesetters lt,magnaflow,no cats,pcmforless, P&P heads,30# injectors 3.73s and new purchase,1996 m6 , convertible ,k&n cai,52mm tb,air and egr delete,skip shift delete My Answer: Car1 - Absolutly not you have them already Car2 - No, your car is relativly stock gillt1 03-15-2007, 07:22 AM OOPs 30# injectors should not be in sig for 95z ,MY MISTAKE SORRY ,was going to install,also have aded a 58mm tb Thanks All SnakeOiler 03-15-2007, 07:43 AM They won't increase hp, if that's what your looking for. As 2000GTP said, check your duty cycles, if over 80%-85% then the 30lbs might not be a bad idea. TobyZ28 03-15-2007, 01:31 PM If your car was struggling up top for fuel you would likely feel it. For a heads /cam car it is possible you may get a little bit more up top if this is the case :D Denny McLain 03-15-2007, 06:40 PM They won't increase hp, if that's what your looking for. As 2000GTP said, check your duty cycles, if over 80%-85% then the 30lbs might not be a bad idea. Personally, I bet money you would get nothing but another bill to reprogram you computer for 30 lb injecters. If you're over 385 to 390 rwhp in a six speed and want to keep the stock fuel pressure, then it's another story. Spend your money instead on sex, drugs and booze. At least you'll be having a good time while your getting screwed. | ||
