Kyle@CSS
11-23-2002, 10:25 AM
I got the box and the wire. I was wondering hows the best way to hook this up. Any links would be helpfull
r/t .622
60' 1.65
330 4.685
1/8 7.190
mph 98.39
1000 9.343
1/4 11.167
mph 122.69
South Carolina F&Y bodies
www.scfyb.com
Injuneer
11-23-2002, 08:06 PM
The January 2003 issue of GM High-Tech Performance magazine has a detailed article on battery relocation.
Projectz28
11-24-2002, 04:12 PM
I was just going to say the same thing as Fred. The Jan issue has a detailed article on how to do it.
kazman
11-24-2002, 06:41 PM
The only thing that I don't like is the battery placement. My car has t-tops and the battery relocation goes right where the tops are stored. BMR makes a bracket that mounts in the spare tire location. The BMR kit is not a battery box just a hold down bracket which will not pass tech. Over winter I'm gona try to relocate the battery in an enclosed case using the BMR bracket. I still would like to be able to drive the car on the street with the tops off. The more I race the less the car is on the street.
N20Dave
11-26-2002, 08:59 AM
The GMHTP article is good but it does not mention anything about how to wire the system to shut down the electrical system/alternator as mandated by NHRA rules. Anyone have any thoughts or links on that?
Brady
11-26-2002, 09:08 AM
A fellow Board Member "Steve10" sells some pretty cool stuff, including a battery disconnect switch.
Check it out at: http://www.mycamaroz28.homestead.com/
matt95z28
11-26-2002, 09:24 PM
Does battery relocation make a big difference?
kirschman
11-27-2002, 09:43 PM
http://flamingriver.com/enter.htm Give these peeps a try on the disconnect switch, looks pretty trick to me. I ordered mine from a local parts store for around 90 bucks. And yes it does help, weight transfer, and of course make the engine bay look alot better!!
edit; scroll down to the battery switches and click on the racing one, its at the bottom of the page.
1fastV6
11-28-2002, 07:42 PM
the 2003 issue?
Injuneer
11-29-2002, 12:01 AM
Originally posted by 1fastV6
the 2003 issue?
Yes. The issue with the feature article about the "Eleven LT1 Bolt-On Cars That Haul".... many of them from this board.
Are you not aware that many magazines are post-dated by several months? I received the January 2003 issue (Volume 9, No. 1) at least three weeks ago...........
:rolleyes:
