OneFreakZ
03-12-2007, 07:29 PM
Hey Guys The Abs Inop Lights Comes On And Stays On Till I Turn Off The Car??dont Know What To Do...:(
Abs Inop????OneFreakZ 03-12-2007, 07:29 PM Hey Guys The Abs Inop Lights Comes On And Stays On Till I Turn Off The Car??dont Know What To Do...:( JAB 03-12-2007, 07:37 PM Get it scanned and see why the light is coming on. It isn't going to fix itself. BlackDog 03-12-2007, 07:44 PM Check the fuse first, then look at all the connections at the abs unit and at the front of each wheel and at the center of the diff. Unplug each connector and look for any signs of dirt and plug the connector back in. The abs is a durable system and any faults are usally a bad connection. Go to my Technical aid section in my sig and scrow down to the brake section there are some links on how to trouble shoot the abs system. 30696bird 03-12-2007, 07:59 PM I "think" it will stay on if you have a blown brake light too. z95lt1 03-12-2007, 08:06 PM my has come on in the past due to 3rd brake light blubs being out, and as said above you abs sensor's on the wheels maybe bad. nb 96 z 03-12-2007, 09:55 PM Also make sure all your electrical connections are not loose at the postitive (red plastic box) terminal box. OneFreakZ 03-13-2007, 05:32 PM hey guys i know my wheel bearings where bad so i replaced the two front hub assembly so i got two new wheel speed sensors for the front im thinking it might be the connectors to the hub assembly becuz i sprayed them with brake cleaner to clean them off i think it must of destroy the connectors???is this possible.. | ||
