Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Injectors
Old Mar 12, 2007 | 05:43 AM
r.serio's Avatar
Injectors
I hope this is in the right catagory.
My question is: What would be the best injectors to use?
Engine Mods: Stock rebuilt bottom end, LE1 heads, CC306, 58mm TB, BBK shorties etc. More to it just making it short.
Should I go with 30lb or 36lb injectors?
Thanks for the help.
Old Mar 12, 2007 | 06:07 AM
Guest47904's Avatar
Guest
Need to know the HP
When picking the injector size, you need to know what HP the combination will produce.
The 30's are good for 384 HP
The 36's are good for 460 HP.
Doubt you will be any where near 384 HP so 30's are more than enough. Easier to find also since I believe Ford SVO's are 30.
Old Mar 12, 2007 | 06:11 AM
r.serio's Avatar
Thanks Speedy . . . 30's it is.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
