not much knowedge of engines.....
BC32
03-11-2007, 06:12 AM
I have a 95 3.4L V6... What is the biggest engine I can put in it's place. what needs to be done? etc..:confused:
2000GTP
03-11-2007, 12:58 PM
The sky is the limit... people have swapped in LT1s, LSx motors, big blocks, forced induction applications, ect. Depends on how much time, money, and patience you have.
Chevy16
03-11-2007, 01:20 PM
i know ive hurd of ppl putting those almost $15,000 527 chevy big blocks in our cars
RS96Silver
03-11-2007, 08:56 PM
do a search and find out what people have done....
smithtim
03-13-2007, 08:33 AM
I've got a 97 V6 that I am pretty sure killed a bearing so I've been looking into swapping it to a 5.7 and it looks like it will work out OK withount to many modifications...
anyways, like listed above, I've heard of people doing all sorts of things.. maybee take a look at this thread if you didn't find it before
http://web.camaross.com/forums/showthread.php?t=150164
jpaul2001
03-13-2007, 02:25 PM
Pretty sure that swapping just the engine won't work. You may have to change the suspension, and transmission as well. I personally wouldn't stop at a 350 if all that has to be changed. I'm considering a 383.
LiENUS
03-13-2007, 02:42 PM
You could put a viper V10 if you wanted... she'd be a bit noseheavy but its doable.
jpaul2001
03-13-2007, 03:21 PM
Now there's a swap I'd love to do!
RS96Silver
03-13-2007, 03:27 PM
any swap is possibly...LT1's r the most common for swaps cuz the parts r easy to come by...but ya u can basically throw any engine into any car...all depends on if u wanna spend the money to do it
LiENUS
03-13-2007, 03:37 PM
The 93s were available with viper 6 speeds and the 94 on 6 speeds were engineered to be tougher than the viper 6 speeds. So the transmission should be able to take a 1st gen viper v10 with nothing more than a bellhousing swap. But you better put a new rear end in it, youl'l kill yourself if you dont.
2000GTP
03-13-2007, 04:22 PM
Has this swap been done before? If so, do you have any info, its got my curiousity.
LiENUS
03-13-2007, 04:57 PM
I saw a picture over on ls1tech.com I think, of what appeared to be a f-body with a viper V10 in it. It barely looked like an f-body as everything was moved, even the radiator. But it was in there... The swap wasn't complete yet though.
2000GTP
03-13-2007, 07:41 PM
Thanks, I'll have to check that out. Just more proof that some people have too much time and money on their hands.:D
