need help ASAP...car wont start!!
krazykorean35
03-10-2007, 06:50 AM
ive got a 98 ls1 m6. i installed a shift light, and had it all hooked up( spliced into the white35 wire in the pcm, power from the asr button and grounded, hooked up the battery...car wouldnt start!...the engine turns over, but just wont kick. friend of my said it was the VATS (vehicle anit theft system) because i had disconnected the battery and that id need to reset it...ive never heard of this. any advice/help??! :confused: :confused: :confused: :confused:
Bayer-Z28
03-10-2007, 12:41 PM
sounds like it interrupted the cam signal to the PCM. Re check the connection to the light, make sure you didn't inadvertently kill the signal/cut the wire.
I take it you used one of the blue splice connectors... ?
krazykorean35
03-10-2007, 02:18 PM
i used pink ones...
krazykorean35
03-10-2007, 03:47 PM
come on!! anyone got any ideas!?!?
98mustang_vert
03-10-2007, 08:45 PM
It could be a bad ignition relay. My car started doing the same, the engine would crank but not start. $11 from Kragen. Relays are located in the fuse box under the hood. Hope that helps.
iamsickofitall
03-10-2007, 08:50 PM
was that pin 35 (white wire) on the blue PCM connector cause that's the one it should be. if it was on the other connector, that may be causing your problem, however i don't know what is on that pin.
otherwise i would check all ignition relays and fuses and make sure that the fuel pump is priming before you go to start the car. if it's not, check those fuses too.
