plusandrew 03-05-2007, 09:50 PM Im currently on the stock 16" wheels, no body kit, nothing has been lowered.
What size tires should I get if I'm getting 17" wheels?
245/45/17 ??
83tpi_3rd-gen(sri) 03-05-2007, 10:01 PM go with a 275. it will fill out the wheel perfect.
bbplayer133 03-06-2007, 05:46 PM 275/40/17 is the one most commonly run
danhr 03-06-2007, 07:08 PM 45's... i say 45's... with those on 17's, it's just a little bigger then the stock 55 series/16 inch rim.
go to the appearance forum and look up my thread that i started.... i have black z06 motorsports on my 97 z and it's not lowered or has a body kit and has 45 series tires on it.
plusandrew 03-06-2007, 07:54 PM cant find your thread via search :confused:
I think I'm going to get 275/40/17s just because they are a more normal tire size.
danhr 03-06-2007, 07:59 PM are you sure? I got my 45's and i wish someone made a bigger profile tire...
here's a few quick pics
http://i122.photobucket.com/albums/o257/danhr/DSCN0423.jpg
http://i122.photobucket.com/albums/o257/danhr/DSCN0427.jpg
http://i122.photobucket.com/albums/o257/danhr/DSCN0436.jpg
http://i122.photobucket.com/albums/o257/danhr/DSCN0434.jpg
Chevy16 03-06-2007, 08:15 PM go with the 275/45/17s!!!!!!:yes: thats what i run on my fronts, no problem, my 18s on the back use to rub but im running oversized ones back there
2000GTP 03-06-2007, 09:36 PM go with a 275. it will fill out the wheel perfect.
Exactly what I would run. One of the benefits of stepping up to the larger rim is the ability to use a wider tire, take advantage of it.:)
z95lt1 03-06-2007, 09:49 PM ok a 245/50/16 is 25.66 inch tall. a 275/40/17 is the same over all height as the 245/50/16 so it will not miss with your speedo, go with the 275/40/17 but if you are looking for more side wall do a 285/40/17 which is 26 inches tall.
danhr 03-06-2007, 09:51 PM I didn't even realize there was a 4 in the 245 in the first post...
yeah def. no 245.... god no.. it would look horrible, you would get lots of curb rash...
275 atleast... on all fours.... with a 45 series.... 40 is just too low, unless you plan on lowering it ALOT.
You could step it up and put 285's on the rims, but if you do that you would either a) run 285's in the back and 275's in the front, and lose the ability to rotate your tires or b) you would run 285's all the way around... but that's oging to be a REALLY responsive front end...
I went 275/45/17 all the way around and I'm happy
z95lt1 03-06-2007, 09:51 PM are you sure? I got my 45's and i wish someone made a bigger profile tire...
bfg makes a 255/50/17 that is about 1/2 inche taller then the 245/45/17
danhr 03-06-2007, 10:00 PM not fond of that first number...255.... way too small. for me it was either 275 or 285... nothing smaller...
z95lt1 03-06-2007, 10:22 PM not fond of that first number...255.... way too small. for me it was either 275 or 285... nothing smaller...
i was thinking you had 245/45/17's on your car, from the pics the tires look skinny.
STAYBG87Z 03-10-2007, 02:17 AM Your gonna want a little taller tire in the back if its stock height cause with the 275/45 doesnt fill in the rear wheelwell very good in my opinion.
there is no 275/45/17
get your **** straight people before giving out advice
Injuneer 03-10-2007, 11:01 AM there is no 275/45/17
I'm glad you said that..... cause I was scrolling down to the bottom to make the same post. :D
i have to say these things in the nicest way possible at work
felt the erge to just lash the hell out :D
felt good :o
