BS on 15X10 w/ 2.5" shortened axle (95 TA)
maro z28
03-05-2007, 03:27 PM
What would be the backspacing for a 15X10 wheel on axles shortened 2.5" on each side. For a 95 trans am.
I have a suspicion of the answer, but I want to be sure. (15X10 bs-2.5??)
Injuneer
03-05-2007, 05:38 PM
Correct.... recommended BS for the 15x10 wheel on a stock axle assembly is 7.5" For a rear that had been narrowed 2.5" on each side, you would subtract 2.5", giving you a 5.0" BS requirement. If you can only get the BS in x.5" increments, it would probably be best to look at a 5.5" BS. Clearance to the inside fender liners might be tight though, with really beefy slicks.
lethal93ta
03-05-2007, 06:07 PM
mine is only narrowed 2 inch's a side and I have 15x10s with 5 inch backspacing on mine 26 11.5 15 ET streets
http://www.streetlethal.net/moser/IMG_0372.JPG
http://www.streetlethal.net/moser/IMG_0418.JPG
http://www.streetlethal.net/new/IMG_0091.JPG
http://www.streetlethal.net/new/IMG_0089.JPG
http://www.streetlethal.net/new/IMG_0096.JPG
xpndbl3
03-06-2007, 01:07 AM
15x10 with 5-5.5 bs
maro z28
03-06-2007, 03:56 PM
Centerline only has 3.5" or 4" bs on 15X6 telstars. i'm not 100% sure on autodrags or convo pros. It was suggested in the wheel/tire FAQ sticky to use 4.5" bs. Could 4" bs work with a spacer? Would I really NEED a spacer?
Also, 16x8, what backspace?
thanks
Injuneer
03-06-2007, 06:02 PM
What backspace works depends on the width of the wheels. But why would you be putting 15x6 wheels on a narrowed rear axle assembly?
maro z28
03-07-2007, 08:40 AM
No, dude, 15X6 in the FRONT.
Injuneer
03-07-2007, 12:21 PM
I guess I was stupid enough to ASSume you were still talking about your original "topic" :rolleyes:
maro z28
03-07-2007, 01:47 PM
What interference would I run into with 4" bs on a 15x6 rim?
I just ASSumed you knew what I was talking about since YOU WROTE THE STICKY! (insert sarcastic rolling eyes-face)
