mightymouse383
03-04-2007, 09:05 PM
$2500.00 or best offer
1987 Trans-Am GTA, black on black, t-tops(not one leak), Dash and seats look like new, Two new BFG drag tires. 255/50 R16.
Now to the motor.
357 small block v8, 10 to 1 compression ratio, cast crank
202/160 64cc heads(iron, gm casting),
292cam(summit) with 1.5 roller rockers,
750 cfm edelbrock carb, performer rpm intake,
700R4 transmission with a 3200 stall converter and 3:73 gears(richmond gears), with rear disc brakes,
Billet hei distributor with phillips plug wires,
aluminum pulleys, forged pistons, summit stage 1 connecting rods, arp main bolts and head bolts, roller timing chain, hedman long tube headers, BFGoodwhich drag radials, K&N air cleaner,
Jegs aluminum radiator with Aluminum shroud and electric fan,
Jegs mini high torque starter, TCI heavy duty Fly wheel, Harwood 3 inch cowl hood.
http://myspace-991.vo.llnwd.net/01331/19/91/1331511991_l.jpg
http://myspace-051.vo.llnwd.net/01357/15/05/1357375051_l.jpg
Runs good and sounds good, just needs a little work
$2500.00 or make me a offer
NICK
Now to the motor.
NICK
