Nossle or plate LT1
z2894droptop
03-04-2007, 01:15 AM
What is the difference and which is better?
Injuneer
03-04-2007, 11:02 AM
How much do you plan to spray? NOSzles are direct port, for large shots.
z2894droptop
03-04-2007, 08:33 PM
200 shot
danhr
03-04-2007, 08:48 PM
the plate from nitrous works is crap... I'm in the process of converting mine to a nozzle.....and getting this damn dis-4 to work with my delteq...
there is a plate from a supporting vendor (it's one of two... and I dont want to say the wrong one). It looks very promising
Loadre
03-04-2007, 10:12 PM
The nitrous outlet is re-releasing their LT1 plate. Look in the nitrous section of LS1 Tech
Ray@NitroDaves
03-05-2007, 10:17 AM
it is posted here also
http://web.camaross.com/forums/showthread.php?t=505125
Ray@NitroDaves
03-05-2007, 10:25 AM
A nozzle kit will mount the nozzle into the intake elbow/bellows in front of the throttle body (TB) and spray towards the TB, A plate will mount behind the TB and ours spray accross the airflow path such that the natural induction of the intake draws the mixture into the manifold.
Our plate has 8 distribution points, instead of one. This will help distribution slightly and a plate will also give you a cleaner install.
200 shot
This is the max we reccomend going to on the LT1 intake without going to a direct port. This is due to the flow characteristics of the LT1 style manifold.
pics of our plate can be found here...
Injuneer
03-05-2007, 01:20 PM
Rereading this, are you asking about a "nozzle", or a "NOSzle" system? They are two different things, and I may have misinterpreted your "nossle" misspelling.
z2894droptop
03-06-2007, 04:31 PM
Sorry, I meant nozzle
2000GTP
03-06-2007, 05:09 PM
Both systems can get you to your goals, the nozzle setup will be substantially cheaper though.
95z28_m6
03-08-2007, 11:04 PM
http://web.camaross.com/forums/showthread.php?t=505125[/QUOTE]
Man that is one trick part.:D
Ray@NitroDaves
03-09-2007, 10:19 AM
and it works as good as it looks:cool:
