maro z28
03-03-2007, 11:39 PM
How much do they typically run and where can I find them? I'm looking for everything, i.e. rotors, calipers, pads, even spindles.
stock LT1 replacement brakesmaro z28 03-03-2007, 11:39 PM How much do they typically run and where can I find them? I'm looking for everything, i.e. rotors, calipers, pads, even spindles. OBE1 95Z28 03-03-2007, 11:44 PM I wouldn't spend the money to buy new stock LT1 brake setup. For the same or slightly more money you could with the LS1 setup which is a much better system (1" diameter large rotors, dual piston calpiers). Do a search on the LS1 brake conversion. If you really want the LT1 setup, there's probably a lot of used parts out there to be had cheap. maro z28 03-04-2007, 12:24 AM The brakes are so I can run Bogart wheels. Will LS1 brakes fit w/ Bogarts? blackztpi 03-06-2007, 12:52 AM yes...whatever you do, don't buy cheap pads. the pads make the brake obviously. i had a set of duralast's and if you stepped on the brakes twice in a row they would hardly stop and when you did it would be a stink smoke fest 2000GTP 03-06-2007, 08:38 AM I definitely wouldn't step down in braking ability. Could you contact Bogart first to make sure their wheels will work around your application? If you do go with the LT1s, people are practically handing them out. When I finally get around to installing my LS1 set, my LT1s will be going to the curb for garbage pickup I'm sure. maro z28 03-06-2007, 10:57 AM Dude send me a pm before you do that. You could sell em to me and at least make something. The Captain 03-07-2007, 01:34 PM I just bought pads for the rear (lifetime warranty) and one rotor cost me $40 Z95m6 03-07-2007, 02:36 PM Dude send me a pm before you do that. You could sell em to me and at least make something. I believe I have my complete old LT1 stuff minus one of the hubs but they're interchangeable between LS1 stuff. The shipping is what would kill you. | ||
