Detailed instructions for bleeding 95 camaro clutch!
FJohnson
02-27-2007, 05:50 PM
I need help, there has to be some technique to bleeding the clutch on my son's 95 camaro. We had the clutch, throw out bearing, master cylinder, slave cylinder and numerous other items replaced. The clutch pedal is very soft and the car will not go into gear unless you pump the clutch several times. How do you properly bleed this type of clutch?
FunkZ
02-27-2007, 07:11 PM
There is no bleed screw on the 3.4 clutch. You have to unbolt the slave cylinder from the trans and drop it down so that it and the line are lower than the master cylinder, then pump the piston in/out to force any trapped air up to the master cylinder.
