Nitro Dave 02-27-2007, 02:48 PM Ok guys, You have been asking and we have been listening.
We designed a LT1 plate over a year ago. After releasing it the sales were not what we needed to keep the production going. However shortly after cancelling the part number we started getting alot of phone calls and emails from people wanting the plate system. So we listened and now is your time to step up to the plate and show us that keeping this part number alive for the LT1 enthusiest is supported by you.
We need 10 orders to be able make this deal happen. This will show us that there is a call for the LT1 plate system. We will then go to production and put the LT1 plate back on the market and keep them instock. Show us you guys are serious!!!
Ok this is the story behind the LT1 plate system.
Back about two years ago we started playing with the idea of a nitrous plate for the LS1 and LT1 community.
We were not happy with the current plate design's that were on the market. The current plate designs placed a plate or nozzles behind the throttle body aimed at the back of the intake. By placing the discharge so close to the front runners and aimed at the back of the intake there was the chance of over powering the back runners and missing the front.
So we went on the quest to develope a plate that would give a nice sexy look and properly attomize to all cylinders. After scraping many plates and throwing away many different desighns it finaly happened. A year later we had came up with a design that would attomize well and looked sexy!!!!
Here is how our design works.
In this picture you will see the distribution ports in the plate. This design works by using 4 nitrous ports and 4 fuel ports in each throat opening. The nitrous and the fuel will slam together and create a plumb spraying across the intake port.(NOT AT THE BACK OF THE INTAKE) Then the induction of the motor will pull the mixture into the intake plenum.
http://img341.imageshack.us/img341/3949/lt1plate3ya4.jpg (http://imageshack.us)
http://img403.imageshack.us/img403/8589/lt1plate4pi9.jpg (http://imageshack.us)
This is the full plate conversion. Consist of Billit Plate, gasket, Throttle extention bracket, 50-200 hp jetting, all hardware
http://img407.imageshack.us/img407/1535/lt1plate800x600ug5.gif (http://imageshack.us)
This is a complete system picture. System comes complete with a bottle capable of flowing 800hp with accessory ports in the side of the bottle valve, 300 hp purge port design solenoids, Stainless quick release bottle brackets, 16ft main feed line, plate conversion, all hardware etc.
http://img341.imageshack.us/img341/2622/0010100or0010101vh2.jpg (http://imageshack.us)
The plates will be comming annodized black with our logo laser etched in. Like this.
http://img85.imageshack.us/img85/7854/blackls1plate04yy1.gif (http://imageshack.us)
Ok So here are the details on this group purchase.
We need a total of 10 orders. It can be in a system form or conversion form. You have your choice of 52mm or 58mm.
It will take ruffly 3-4 weeks from the time the special ends for us to be able to ship the product.
Regular prices are.
Conversion=285.00
System=699.99
This is the special price's
Conversion= 250.00
System= 599.00
You can call in your order toll free at
1-866-648-7637
Local is 254-420-3630
Thank you for support.
Dave
2000GTP 02-27-2007, 03:38 PM What kind of shot will this system support? What is included in the conversion kit?
Ray@NitroDaves 02-27-2007, 03:50 PM the plate itself can flow 350+...but I would not go over 200hp on a plate or nozzle setup on a LT1 Intake. Anything higher than 200 would be safer on a direct port.
The conversion will come with everything needed to switch from a nozzle to the plate.
Plate, jets bolts, brackets, gaskets, etc
Can this be used on other nitrous system besides the Nitrous Outlet sytem?
Ray@NitroDaves 02-27-2007, 04:13 PM Can this be used on other nitrous system besides the Nitrous Outlet sytem?
The plate is compatible with any brand nitrous kit.
97 RedSS 02-27-2007, 11:59 PM How thick is the plate? Any problems with aligning cold air intakes on the TB after installing this? With just the stock TB w/out the plate my SLP cold air intake comes very close to the fan shroud on the front of the engine. I think with the added thickess of the plate it wouldn't fit correctly..
Nice looking system though!
Also, you guys are located in Waco correct? I drive through waco atleast once a month and was wondering if it would be possible to stop-in and buy a kit to save on shipping costs???
Cody
Ray@NitroDaves 02-28-2007, 12:02 AM I will double check but I think they are 3/4" thick.
Shouldn't affect the placement of the CAI enough to worry about, will just change the angle of the elbow slightly.
You are welcome to pick one up in person.
update:
The last batch were 3/4" thick...but we are going to try to get them a little thinner this go around
mcshocks 02-28-2007, 12:15 AM I will call in this week for 1, what hours are you guys open and what time zone?
Ray@NitroDaves 02-28-2007, 10:06 AM I will call in this week for 1, what hours are you guys open and what time zone?
Our hours are 9am the 5:30pm CST.
Ray@NitroDaves 02-28-2007, 10:16 AM I will update this list as orders come in.
1) DC Motorsports
2) TwoFast4Lv
3) 96blkform
4) mcshocks
5) Blackramair99
6) TWS
7) Loadre
8) 96 N20 Z
9) ???? Chris didn't ask for the board name
10) Zigroid
Ray@NitroDaves 02-28-2007, 03:29 PM updated post #10
Ray@NitroDaves 03-01-2007, 02:23 PM Updated List
DirtyDan 03-03-2007, 04:12 PM PM sent
KENS80V 03-05-2007, 10:55 AM I'd be interested if it were closer to 1/2 inch in thickness. Please keep us posted on the final thickness.
Thanks,
Ken
IROC-Z28_CAMARO 03-05-2007, 09:33 PM Will this work with the stock throttle body?
Ray@NitroDaves 03-05-2007, 11:03 PM yes it will work with the stock TB....if you have the stock TB and no interest in adding the 58mm at a later date get the 52mm plate. If you are going to add the 58mm later, get the 58mm plate and have the intake bored to 58mm, to remove any lip that might be present behind the TB.
Nitro Dave 03-09-2007, 02:52 PM Wow. I must say the LT1 guys really steped to the plate on this. You guys rock!!!!We had more than enough orders to go to production the same week this post started. The order is in and we are waiting on the machine shop at this point. Do to the responce and support we will be bringing this part number back to life.
For the guys that did not pre order. You can still place your order and get the discounted price till the end of next week. MARCH the 23rd is the deadline on this special.
Thank you guys for all the support.
Dave
DirtyDan 03-09-2007, 03:19 PM I knew all the overtime last month would be put to good use :devil:
KENS80V 03-10-2007, 06:08 PM Does the included modified cable bracket have provisons for an automatic (700R4) TV cable?
Ken
DirtyDan 03-10-2007, 10:35 PM Does the included modified cable bracket have provisons for an automatic (700R4) TV cable?
Ken
When I called Ray earlier this week he said it did.
Z-RATED94 03-11-2007, 10:52 AM I knew all the overtime last month would be put to good use :devil:
Good for you. Making the car quicker is always a good reason to put some extra hours in. ;) And Dave, why not have a few extra made up, even if you can't give the same price in the future?
Nitro Dave 03-12-2007, 10:21 AM Guys,
Our plate conversion does not have a extra bracket for the TV cable on the 93s. The conversion only has a bracket for the throttle cable. I have not tried to see if the tV cable on the 93s are long enough to allow extending forward a 1/2 to 3/4 on a inch. You may have to get creative with your stock bracket. Then again you may be able to just re adjust it. Im not real sure on that one.
Z rated94. We did order more. We have to geta lot more than 10 machined in order to keep it cost affective. I just wanted a commintment of 10 to show us there was a need for this product. Thanks to quite a bit more than 10 people you guys showed us there was a need for this product.
Thanks Guys.
Dave
Amped96 03-13-2007, 11:06 PM Will the plate be available on your website soon?
Nitro Dave 03-13-2007, 11:11 PM Yes once we get them instock they will be on the website at normal cost.
Dave
DirtyDan 03-14-2007, 12:09 PM Dave, do you have the final dimensions of the plate yet? If you can get me a final thickness of the plate I will talk to one of our vendors at work and see if they can make a cost effective bracket to replace the ones on the 93. I do know that on my 93 there is not enough cable adjustment for the plate thickness. That is why I asked about the new backet when I called.
T/A KID 03-14-2007, 12:10 PM How are the Monoblade orders coming :bow:
Ray@NitroDaves 03-14-2007, 02:43 PM we have 2 orders placed for the monoblade
rock1501 03-16-2007, 07:58 PM I dont know much about setting up N2O but I have a singleplane intake with a 90 degree elbow with a monoblade on my solidroller 383.
will this system work for me?
what about shipping to L1S6A2(toronto Canada)
thanks
Dave
Nitro Dave 03-19-2007, 01:13 PM Yes as long as the elbow does not have a really tall flange on it that would block the clearence of the fittings. Yes we can ship to Canada.
Dave
KENS80V 03-23-2007, 10:36 AM We are still waiting to hear how thick this new plate will be. Today is the final day of the introductory price. Will this plate also work with a TPI plenum? I don't see why it wouldn't.
Ken
Ray@NitroDaves 03-23-2007, 12:38 PM the new plate should be ~1/2" and should work on a TPI manifold
KENS80V 03-23-2007, 08:17 PM Please put me down for a Lt1 plate at this introductory price of $250. I tried to call in the order this evening but you were closed and I don't see it listed on your website yet. I will phone the order in on Monday.
Ray@NitroDaves 03-24-2007, 01:38 AM give me a call monday and I can get it in the GP for you.
mcshocks 04-21-2007, 12:50 PM Hey Ray, I still have not recieved my plate setup, have you sent these out yet? Sent you a email asking for a refund if possible, never heard back?
Nitro Dave 04-22-2007, 11:32 PM Hey Ray, I still have not recieved my plate setup, have you sent these out yet? Sent you a email asking for a refund if possible, never heard back?
None of the units have shiped yet. We have been waiting on the machine shop to finish up. We are still on the time line I set forward in the oriinal post. I stated it would take RUFFLY 2 to 3 weeks from the time the special ended before we started shipping these units. When I talked to the machine shop last week he said he had a machine go down but we should have them this following week.( The week of 4-23- 07)
I will gladly cancell your order and credit you back. However you will need to cover the credit card fees we are charged for processing your order and then crediting it back.
All of our pms were messed up last week and we could not access them. They are fixed and working now so I am sure Ray will PM you back when he catches up.
Or you can give me a call and I can help you.
Dave
96N20Z 04-27-2007, 09:22 AM I have gotten everything but the plate. Is that right? Don't want to have the wrong stuff.
Mark
Nitro Dave 05-01-2007, 10:38 AM I have gotten everything but the plate. Is that right? Don't want to have the wrong stuff.
Mark
Mark,
What is the last name on your order? Ill look it up.
Dave
Nitro Dave 05-01-2007, 10:39 AM Ok guys here is an update.
April the 20th was our 4 week target. It is now April the 30th so we are right at alittle over a week of my target deadline. In my original post I carefully put RUFFLY 3 to 4 weeks in there.lol
The process has taken longer than I hoped but the machine shop had a machine go down that pushed us back.
The plates are finshed and have been laser etched and annodized. We are waiting for the throttle brackets to come in and enough gaskets to fill all the orders. We bought our supplier on the gaskets out of stock.
I will have some really nice pictures of the plates up by the end of the week. Some may ship the end of this week depending on when the wot brackets get here.
I am real certain that when you see this plate it will be worth the wait.
Thank you guys for all your support and patience..
I really do appreciate you guys.
Dave
Moshbmx1 05-01-2007, 11:52 AM These look so tempting to get. Too bad funds are low already this year :(
Greaseymec 05-01-2007, 05:20 PM Hey Dave. Do you have one that someone backed out on? I like the way you described how the gas and fuel mix with these plates. I dont have a nitrous setup yet but would like to get a plate now and maybe with your help, put something together soon. I have a 58mm TB. Let me know.
Mec
Nitro Dave 05-04-2007, 06:19 PM We had extra stock built with the ones that ran on group purchase. We will have the systems and conversions on the web site next week. Or you can call in to place your order.
Dave
Nitro Dave 05-04-2007, 06:20 PM Some eye candy....
Better pics comming soon.
http://img177.imageshack.us/img177/9819/lt1plates2bn0.jpg (http://imageshack.us)
mattbailey 05-11-2007, 03:34 AM Dave, could you pm me a price of the complete 58mm plate kit shipped to 42765? Thanks
Ray@NitroDaves 05-11-2007, 10:18 AM Dave, could you pm me a price of the complete 58mm plate kit shipped to 42765? Thanks
PM Sent
94NDTA 05-13-2007, 02:18 PM Will these plates reduce the chance of an N20 backfire? Do you just put the jets you desire in the plates? I am interested, this will clean up my set up a lot.
KENS80V 05-15-2007, 11:06 AM Have these plates been shipped out yet? I'm the only buyer in Canada and I asked to be notified when they are sent so I can avoid the extra fees thru UPS.
Ken
Ray@NitroDaves 05-15-2007, 11:29 AM Have these plates been shipped out yet? I'm the only buyer in Canada and I asked to be notified when they are sent so I can avoid the extra fees thru UPS.
Ken
The 58mm plates started shipping last week...you have a 52mm on order...they should be here today and should be shipping w/in the next couple of days.
It is noted on your invoice to call you before shipping.
Loadre 05-15-2007, 01:23 PM UPS came to drop mine off yesterday but I wasn't here. ARG. Should be here in a couple hours muahahhaha.
96blkform 05-15-2007, 03:38 PM Awesome, means that mine should have shipped last week too :) Have not seen it yet, will have to keep an eye out for it.
Nitro Dave 05-15-2007, 05:59 PM Here are some pics to hold you over until the ups man gets there.
http://img245.imageshack.us/img245/2820/p5100001sj0.jpg (http://imageshack.us)
http://img185.imageshack.us/img185/3139/p5100002of7.jpg (http://imageshack.us)
http://img385.imageshack.us/img385/8688/p5100001wt9.jpg (http://imageshack.us)
Dave
Loadre 05-15-2007, 06:05 PM Looks sorta like what just showed up at my door :)
Nitro Dave 05-15-2007, 06:30 PM Hey guys. Just a FYI
We did not send instructions with the plate conversion. They will come with them in the future. We just need to get them together. So Im going to explain how to attach the throttle extention bracket here in this post. The rest is self explanatory.
1. The conversion will come with three small extention bracket pieces. These pieces have two holes in them. A counter sunk hole and a threaded hole. Using the counter sunk screws that come with the conversion bolt the bracket to the intake through the counter sunk hole. The extentions will be reaching towards the face of the car. Do not fully tighten.
2. Then take your factory Throttle cable bracket and bolt it to the extention brackets using your factory bolts. They will thread into the threaded hole in the extention bracket.
ATTENTION. You will need to grind your factory throttle cable bracket at the bottom for clearence reasons.
3. Fully tighten the counter sunk screws.
http://img217.imageshack.us/img217/7246/bracketsinstalledpx9.jpg (http://imageshack.us)
Another picture comming soon.
Let me know if you have any questions.
Dave
Loadre 05-15-2007, 06:42 PM Yeah I saw those things in the back and was like WTF? then I finally figured out what they were for.
