fireman
02-15-2007, 11:12 PM
When I am cruising around and click my Scanmaster over to MPH, it reads like 24mph when I am going like 60mph. Whats weird is my speedo is accurate.
I would imagine the Scanmaster pulls its info form the PCM, which pulls the speed info from the sensor on the trans.
thoughts?
speedygonzales
02-16-2007, 06:57 AM
Let's ad more confusion. The VSS sends it's signal to the PCM which inturn sends it out to the instrument cluster to signal the speedo too. Figure that one out.
fireman
02-16-2007, 10:01 AM
Injuneer?
I might try and call the Scanmaster people today and see if they have any info..
Injuneer
02-16-2007, 10:33 AM
I can't figure it out. It would almost indicate that the VSS was putting out a 17 pulse/rev signal used in an M6, but the PCM was programmed for the 40 pulse/rev signal produced by the A4, and someone had inserted a signal converter like the Dakota Digital unit between the PCM and the speedo.
Wrong forum.
fireman
02-16-2007, 04:54 PM
I think my PCM may have an auto tune in it. I know that it throws a couple DTCs that are related to an auto trans.
There certainly is no converter of any kind in there. I also have 2 different instrument clusters and the result is the same with both.
It'll be Monday before I can ask the Scanamster people.
Injuneer
02-17-2007, 10:23 PM
The converter would not be in the instrument cluster. It would be in the wire for the speedo, that runs from the PCM to the panel.
fireman
02-18-2007, 11:34 PM
Hmm, no converter there either.
very strange
